Old 12-06-2008, 06:28 PM   #1
Default Mamba Max ESC on/off switch
The on/off swith for my mamba speed control has unfortunatly come off and i have lost it as well. I was wondering if i could take an on/off switch from one of my older speedos such as the Tamiya ESC that comes with most of their kits. Do any of you guys know if this will work. Thanks in advance my fellow RCer's. A.J.
SpeedKills25 is offline   Reply With Quote
Old 12-06-2008, 06:34 PM   #2
kufman's Avatar
Anything that will make contact between the two wires that used to go to the switch will work. You could even twist the two wires together and it will work just fine (soldering would be better for long term use).
kufman is offline   Reply With Quote
Old 12-06-2008, 06:35 PM   #3
porkey's Avatar
You can bypass it. You just take the positive and negitive wire and wrap them around, then put a thin pice of heat shrink so it dont come apart.
porkey is offline   Reply With Quote
Old 12-06-2008, 06:45 PM   #4
HEAT's Avatar
Trader Rating: 26 (100%+)
I took the switch off and soldered the + and - together and it works fine .
HEAT is offline   Reply With Quote
Old 12-06-2008, 06:58 PM   #5
Wow, thanks a lot guys for the quick replies. It looks like i will be using the wires from a broken speedo that i have laying around. The only problem with soldering the wires to the mamba is the fact that the speedo doesn't provide much room for soldering. My soldering iron is a radio shack brand which works nice, but im afraid the tip is too large to fit into the small area where the wires will be connected. Is there actually a way to do this without soldering at all? Thanks guys.
Old 12-06-2008, 07:23 PM   #6
glassdoctor's Avatar
If the wires have pulled away from the circuit board, then you have to solder wires back on, yes.
Actually you have 3 options...
1. get an iron with a small tip and solder on new switch leads.
2. ditch the switch, and the wires... and use solder as a "jumper" across the contacts on the circuit board. That might be easier to do with the iron you have anyway. It's not too hard to get the solder to flow and connect the two spots. Just do not keep the iron on the board too long... if it doesn't work right away, let the board cool and try it again.
3. send it back to Castle and they will do it for you... and be aware that soldering on the boad does void the warranty
glassdoctor is offline   Reply With Quote
Old 12-06-2008, 08:51 PM   #7
Thanks for this useful information my friend. My only question for you is in part number 2. So if i ditch the switch and bridge the tabs with solder, how will i turn the ESC on and off? Will this just happen when i plug a battery in? Im about to go ahead with this method as i type.
Old 12-06-2008, 10:08 PM   #8
Dadx2mj's Avatar
I did away with my switch long ago after the tech support guys from Castle made that suggestion to me.
Yes plugging your battery in with activate the system and unplugging it shuts it down. It is as simple as that.
BlindManRacing
Powered by Mamba 5700
Dadx2mj is offline   Reply With Quote
Old 12-06-2008, 10:12 PM   #9
You're dead right. Plug the battery in, and she's all go
The switch is handy when you can locate it outside the shell, but with most race cars it is inside, and so it's use is pretty much redundant!
JR007 is offline   Reply With Quote
Old 12-06-2008, 10:20 PM   #10
You guys are the best. I did exactly what you said and it was a success. Thanks again. A.J.
Traxxas Revo futureal Monster Trucks 3275 11-23-2017 07:38 AM
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! Joe Ford Team and Company Discussions 2371 08-07-2017 11:37 AM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 06:31 PM
Is this normal behaviour for a Mamba Max? + some BL terms Qs shurcooL Electric Off-Road 19 08-15-2008 03:56 AM
