-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   how to tell if it is v2 or v3 mamba ? (https://www.rctech.net/forum/electric-off-road/257503-how-tell-if-v2-v3-mamba.html)
russo11218 12-02-2008 06:16 PM
i was just woundering ...I just got around to opening the box of my 1/8 mamba speed control the box say's it is a v3 speed control via label on box .While i was going over the manual it mentions on seprate small peice of paper that this is a v-2 controller and and that the fan will not turn until it hit's 150 Deg .So what i am trying to figure out is how can i tell if it is a v2 or v3 mamba ?
lutach 12-02-2008 06:44 PM
You can carefully open the case and see if the brain board is a blueish color.
Klen420 12-03-2008 09:26 PM
just wondering about what turn motor it comes with
the higher the kv the lower the turn?
SpEEdyBL 12-03-2008 09:48 PM
I thought the MMM V2's have the 6.5mm bullets on both the motor side and the battery side while the V3's only have bullets on the motor side. If I were you I would not open the MMM case. Why risk fate and voiding your warranty? The most important update is the V3 software which can be downloaded anyway.
Klen420,
both motors that castle will be offering are 1 turn in Y configuration, but don't pay attention to this number. The only differnce between the 2200 version and the 2650 is the length. The longer the motor (keeping everything else the same) the lower the kv, and the bigger gear it will be able to pull. Yes, lower turns = higher kv, but this is only valid when you are comparing two otherwise identical motors, only different number of turns.
nexxus 12-03-2008 10:54 PM
If it blows up, it's a V2
skelly1344 12-04-2008 06:14 AM
The info about the fan kicking on at 150F is included in the V3 boxes. It was a change they incorporated in the V2's and remains in the V3's as well. If your box says V3, it's a V3. By the time they printed the V3 labels, they had long since stopped production on the V2's.
rdub202 12-04-2008 08:46 AM
bahaha, perfect answer
RBMike 12-04-2008 10:42 AM
You don't have to open the case just look thru the top at the fan. If the fan is very close to the grill it's an old one. The V3's fan has alot more clearance. Also if it says V3 on the sticker (on the box), it's a V3.
Klen420 12-04-2008 08:33 PM
Originally Posted by SpEEdyBL (Post 5125307)
Klen420,
Ok that explains it perfectly
thanks for the info:D
tdeal823 12-24-2008 09:02 PM
is this correct? just checking. mine only has bullets on the motor side.
I bought it in the combo with the 2200kv
T4 Razer 12-25-2008 11:18 AM
its a V3
Content © 2001-2011 RCTech.net
