Old 12-02-2008, 07:44 AM   #1
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Default What do you use for removing double sided tape residue?
I usually use goo-gone, but wonder if anyone has something that works better....
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 12-02-2008, 08:08 AM   #2
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Motorspray + flathead.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 12-02-2008, 08:10 AM   #3
badassrevo's Avatar
WD-40 let it sit and scrape it off.
I use ShoeGoo to hold everything in my cars. It is super strong and when removed leaves no residue.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 12-02-2008, 08:21 AM   #4
jmcvicker's Avatar
Check the hardware store for "Ooops! - multi-purpose remover" Works similar to WD-40 (let soak, then remove tape and re-apply to clean) but is in a drip-applicator and not spray.
jmcvicker is offline   Reply With Quote
Old 12-02-2008, 08:30 AM   #5
d4man's Avatar
I use mineral spirits.....
d4man is offline   Reply With Quote
Old 12-02-2008, 08:37 AM   #6
Trader Rating: 69 (100%+)
+1 for WD40 let it soak a bit
marvi is offline   Reply With Quote
Old 12-02-2008, 08:40 AM   #7
gndprx's Avatar
Trader Rating: 18 (100%+)
Just make sure and wipe the area down with rubbing alcohol or similar after to get the residue from the wd40 off...nothing will stick again otherwise
Carl Fisher
Team Xtreme RC
The Grove Racing Center
gndprx is offline   Reply With Quote
Old 12-02-2008, 08:47 AM   #8
y2kgtp's Avatar
I guess I like the goo gone, it's just a pain to use as it seems wasteful with such a large opening on the container onto a paper towel or such....
Old 12-02-2008, 10:38 AM   #9
sneek into your wifes bathroom and get their bottle of finger nail polish remover. Works great, been using that for 20years. Seems to be plastic safe as well.
cherokee is offline   Reply With Quote
Old 12-02-2008, 10:42 AM   #10
y2kgtp's Avatar
You have been sneaking into my wife's bathroom for 20 years?
Old 12-02-2008, 10:48 AM   #11
Only to plant cameras....my real name is Chuck Berry
Old 12-02-2008, 11:32 AM   #12
gndprx's Avatar
i.e. Acetone since that's typically the major chemical in nail polish remover. Just be careful if you are using this on CF as it will eat right through the shine.
Carl Fisher
Team Xtreme RC
Old 12-02-2008, 12:46 PM   #13
i use white spirits on mine, removes all stickyness and drys to leave it fine for resticking. if you are worried then use a little motor spray or meths for cleaning
rallsracing.com, Team Customblitz, HPI
niggs98 is offline   Reply With Quote
Old 12-02-2008, 01:13 PM   #14
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
1st use a good servo tape like bud's. it wont leave crap like the cheap stuff that sadly looks the same.
if need to remove the crap. the quick easy way is with traction compound. yes traction compound. just like traction itself, paragon works best heh
R
UltegraSTI is offline   Reply With Quote
Old 12-02-2008, 01:37 PM   #15
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
3M has a double sided tape I get at walmart that is clear in color with red colored backing. It rolls right off without residue. Only double sided tape I'll ever use.
Here is a link showing you what it is.
http://www.officesupplieslane.com/mmm4010.html
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
