Old 07-24-2009, 11:45 PM   #316
adrictan's Avatar
[QUOTE=ShibbyUTD;6112620]I see the Caster runs two packs in a series. Does that mean much higher run time than a single pack?
Hmm...Tht's my truggy when it was still clean and bare. Ha! As Mike has said, packs wired in series gives u higher voltage so runtime is the same. i.e 2x 7.4v 5000mAh packs wired in series will give you 14.8v 5000mAh making it a 4s 5000mAh. I think you can try making a parallel connector instead of series if you want longer runtime. You'll ended up 2s 10000mAh with 2 x 7.4v packs. I'm thinking of doing up a 2 x 14.8v 5000mAh in parallel to give 4s, 14.8v 10000mAh. Correct me if I'm wrong. I'm still searching......
Sponsors: T-Bone Racing, Misfit Design Group, Maclan Racing, IB Prostart, PTRC Oils, Vision Racing Products, SRT Servo, Boca Bearing, Soar Seiki.
Soar Enquiries: [email protected]
adrictan is offline   Reply With Quote
Old 07-25-2009, 11:34 AM   #317
hakmazter's Avatar
You would be correct adrictan.... Planning on running an enduro race or something?????lol.
I mass produced the first electric 1/8 scale buggy and truggy.
www.HopeWDM.org
I have thousands of dollars of caster racing inventory available.
Semi-Retired from this industry at this time.
hakmazter is offline   Reply With Quote
Old 07-25-2009, 10:16 PM   #318
adrictan's Avatar
Unfortunately, tht's how we, the electrics have to run if we want to race with the nitros. The Finals run for 40mins.
Old 08-07-2009, 07:43 AM   #319
JAM MaxAmps's Avatar
Just be careful with that amount of weight in the car. It would be tough on any brand. I honestly don't see two 4S 5000 packs being a wise choice. Your only going to have issues. I would stick to the smaller packs and have a good pit guy to do battery swaps for you. I've seen it done and if done right very affective.
Jason
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
Caster ex1 electric buggy tinknocker81 Electric Off-Road 35 12-10-2009 10:58 AM
How much R&D will the big names put into 1/8 electric? rearviewmirror Electric Off-Road 48 12-30-2008 04:35 PM
