Old 11-27-2008, 06:33 AM   #1
Default Losi XXX-CR - Which Extra Parts to have?
Getting into the Losi XXX-CR. Can people please put forward the parts that need replacing the most so I can have them on standby! Cheers.
lukewatson16 is offline   Reply With Quote
Old 11-27-2008, 06:46 AM   #2
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Front arms , spindles/carriers , extra E-clips , rear hubs , pins for rear axle , some extra screws and ball studs . I put Lunsford Super Duty Plus turnbuckles and their ball studs on my XXX-CR , stronger then stock .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-27-2008, 06:59 AM   #3
TNS Racing's Avatar
Briguy: how do you like the xxxcr? Any tips or tricks during the build? How does it run on the track?
the true purple and yellow
Team Associated/ Seidel Racing/ Team Scream Racing/ Nike 6.0/ RC Madness
b4.1 novak gtb/ velociti 6.5r
b44.1 lrp sxx tc spec v2/ velociti 5.5r
TNS Racing is offline   Reply With Quote
Old 11-27-2008, 07:26 AM   #4
Briguy's Avatar
I love it ! Best Losi 2wd buggy yet , IMO . I ran 1/2 oz of weight in front of servo and 1/2 oz on the front bulkhead . When switched to lipo I put 1/2 oz on the chassis right next to battery channel on both sides , rear and front . For the tracks I run at I think it handles great . The proper tires/foams play the biggest role though , without them it won`t matter what setup you use . Which goes for any RC . Other then Lunsford stuff mentioned earlier , about it .
Royal R/C & Hobby
Old 11-27-2008, 07:44 AM   #5
HEAT's Avatar
Trader Rating: 26 (100%+)
Front arms , spindles/carriers , rear hubs and ball studs .
HEAT is offline   Reply With Quote
Old 11-27-2008, 03:29 PM   #6
scrawl's Avatar
Ballstuds are the most replaced item on my XXX-CR. Must be why Losi put so many holes in the rear hubs and shock tower.
stivesrc.org.au
"It's a spending hobby. You race occasionally."
scrawl is offline   Reply With Quote
Old 11-27-2008, 04:31 PM   #7
Klen420's Avatar
I just got my xxx cr too! Thanks for the info!
Klen420 is offline   Reply With Quote
Old 11-27-2008, 07:02 PM   #8
Briguy's Avatar
LOL , I hope your kidding .
Royal R/C & Hobby
Old 11-27-2008, 07:11 PM   #9
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
when i had mine i kept the standards like an arm set, carriers and spindles (f/r) but remember rear block parts. often forgotten but crucial
R
UltegraSTI is offline   Reply With Quote
Old 11-27-2008, 07:13 PM   #10
scrawl's Avatar
Wish I was. In 11 months of racing, I've broken 1 front arm, 1 rear pivot block and 6 ballstuds - 4 on the rear hubs and 2 on the shock tower.
Got some Lunsford ballstuds in reserve now - they're going in when the next ballstud snaps.
stivesrc.org.au
Old 11-27-2008, 07:14 PM   #11
hyperguy's Avatar
Trader Rating: 22 (100%+)
the guys at my local track have been bending the rear hinge pin brace so i would reco one of those, but then again i dont run a losi sorry.
hyperguy is offline   Reply With Quote
Old 11-27-2008, 08:59 PM   #12
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
I've been running the car pretty hard since it came out. Maybe I can give you some insight into the parts you might want to have on hand. Every car is going to have a weak point when you hit something so it becomes a matter of where each company isolates that weak point in the design of the car to determine what is going to break the most often.
Front arms are good to have. I've broken a few of them. I found a graphite front arm can hold up quite well. Have extra rear hubs on hand. Any vertical ballstud setup is going to break ballstuds. I'd run a titanium ballstud in the rear hub. The nice thing about the rear hub is that you can switch sides after you break a ballstud and still use the hub. They are universal as to which side they can go on.
Honestly, outside of those two parts, I can't say I've broken much of anything else. Maybe an occasional turnbuckle. I find the car to be very sturdy and anytime that I've broken the car I definitely deserved to break it.
Good luck and hope you love the car like I do!
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 11-29-2008, 10:43 PM   #13
Thumbs up xxx cr
PARTS FOR SALE
GOT EVERYTHING AND ANYTHING YOU NEED VERY CHEAP
PM FOR INFO AND PRICES
and will trade for other items
Team horchata is offline   Reply With Quote
Old 11-30-2008, 07:54 AM   #14
Briguy's Avatar
Sell in the for sale section , not every Losi thread .
Royal R/C & Hobby
Old 11-30-2008, 08:13 AM   #15
Trader Rating: 16 (94%+)
I have about 4-months of racing on my XXX-CR, only broken a single front arm. As for maintenance, only a single diff rebuild to date. A few of the stock balls inside the diff actually broke. I have replaced all with Ceramic balls.
Ballstuds: Following the advice from the guys in the LHS, I replaced all the stock ballstuds with the Losi Titanium ballstuds. I was informed at the time of purchase that all the stock ballstuds break easily, and it not replaced with the Titanium ones, I would also be replacing the part that the stock black ballstud broke off within. Following that advice, I never installed the stock black ballstuds and used Titanium on all suspension links from from the get go, and low and behold, NEVER broken one yet.
LOL - I used one of the Losi stock black ballstuds on a hard to reach spot on my AE T4, and sure enough, that damn Losi ballstud snapped and I had to replace the front shock tower.
kn7671 is offline   Reply With Quote
*** -- Previous Losi XXX-NT AD2 Deal PARTED OUT -- *** Scarab R/C Items: For Sale/Trade 19 08-13-2009 06:12 PM
Out of hobby sale lucky579 R/C Items: For Sale/Trade 36 06-24-2004 01:25 AM
Getting out Sale!!! CE, Losi, Ko Propo, SMC jpolachak R/C Items: For Sale/Trade 6 06-22-2004 07:01 AM
Sellout part 2 lucky579 R/C Items: For Sale/Trade 10 05-14-2004 04:41 PM
Complete Sellout, No Trades lucky579 R/C Items: For Sale/Trade 6 10-03-2003 09:37 AM
