Old 11-26-2008, 04:23 PM   #1
Dean Rawlinson's Avatar
Default A little confused about novak 17.5 in B4
First off, i have read all the threads about gearing on these, but i did not find an answer to my question.
I bought a GTB/17.5ss for my B4. I put everything in the car last night and it went together fine. I picked up a 31 tooth pinion because i have read so many times that these need to be geared to the moon to be fast.
So last night i put this pinion on it and it barely fits on with the stock 81 spur, the gear mesh is kinda nice. I knew this would be low for a 17.5
While test running, it is pretty fast and has a ton of torque, but, its getting hotter than id like on this low gearing. At not even the end of the run, i could hold my finger on it for 7 seconds, no longer. (I dont have a temp gauge yet)
So I am wondering if this is normal, because i hear about people using like 66 tooth spurs and stuff. could my gear mesh be doing this?
thanks,
Dean
If you dont crash, you win.
Dean Rawlinson is offline   Reply With Quote
Old 11-26-2008, 04:32 PM   #2
What up?'s Avatar
Trader Rating: 14 (100%+)
thanks,
Dean
How are you testing it. On a track, Front yard, Street.....? That gearing is low for even a truck so it working at a hight RPM all the time. If you dont want to change the slipper out run the 78spur with a 33 pinion and see how that works. Its still alittle low but your motor will run much better and you will like the performance.
always run the car for a couple minutes and check the temp if your not sure.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 11-26-2008, 04:44 PM   #3
Thanks for the response.
I have heard undergearing can cause problems, but i didnt think it was too undergeared. so if i get a 78 spur and a 33 pinion it will run cooler?
the speed control wasnt the least bit hot
edit: i was just running it around up and down the street
Old 11-26-2008, 05:30 PM   #4
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
72/30...dialed.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-26-2008, 05:54 PM   #5
HEAT's Avatar
Trader Rating: 26 (100%+)
A buddy of mine runs 76/34 or 78/34 .
HEAT is offline   Reply With Quote
Old 11-26-2008, 06:15 PM   #6
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
Also check that the bearing on the shaft side of the motor isnt seized. I bought a novak 17.5 a while back and the bearing was seized right out of the package, the motor ran, just super HOT.
*Vandal 4wd Late model*XXX-T sprinter*Micro scale specialties 1/24 'rock monster' crawler*MSS Micro-Rail*MSS Micro-Funny*MSS Micro-Outlaw*
2wdMod is offline   Reply With Quote
Old 11-26-2008, 09:21 PM   #7
Thanks for the responses.
I plan on getting a 78 spur and a bigger pinion. I have read that the spur from a kyosho zx5 will fit if you trim the slipper pads, is this true?
i dont think the front bearing is seized, it rolls really smooth and its not really hot, but i think i will check it out anyway,
Dean
oh, and ill be running this at ocrc, if that helps
Old 11-26-2008, 11:08 PM   #8
well, the front bearing is fine, now i am trying to figure out how to put it back together.
is there a trick or something that i am missing??
Old 11-26-2008, 11:16 PM   #9
aeRayls's Avatar
I'd say if you could hold your finger on it for 7 seconds, its not too hot. Too hot would be 2 sec or less. With an 81/31 I'd say your about 9 teeth under geared. 66/34 should be pretty good. Though this will of course need modifications.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 11-26-2008, 11:33 PM   #10
Krio's Avatar
Trader Rating: 150 (99%+)
If you think you have power now, wait till you gear it properly. Like you've read, you need to gear it to the moon. I run 33/66 and after racing for 10 minutes the motor is only 125
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-27-2008, 12:07 AM   #11
sweet, i cant wait!
but i seriously need help getting this motor back together!! i cant get the 3 screws to thread in all the way. I really need some help because i dont want to ruin it, it only has 1 run on it.
thanks a lot,
Dean
Old 11-27-2008, 08:53 AM   #12
never mind, i got it together
Old 11-27-2008, 09:34 AM   #13
Trader Rating: 49 (100%+)
what gearing do you guys recomend for a 13.5? right now i am running 78/29... thanks
cleblanc is offline   Reply With Quote
Old 11-27-2008, 09:42 AM   #14
Trader Rating: 29 (100%+)
What Brand & Model of Spurs are you guys using & where did you buy them? I'm trying to locate anything smaller than a 75 locally and not having any luck.
I've got the B3 Slipper Mod right now, gearing it 33/75 and the motor is basically cold after a run.
w-fly is offline   Reply With Quote
Old 11-27-2008, 11:57 AM   #15
The lowest spurs associated makes are 78t. I have heard a 74 or 76 tooth kyosho zx5 spur will fit with a little modding.
where are people getting 66t spurs??
