Old 11-25-2008, 06:48 PM   #16
Trader Rating: 95 (99%+)
Originally Posted by whitrzac View Post
how are you going to inforce a spec class? spec each car after every race?
It takes all of about 15 seconds to tech a slash to see if it is within the guidelines are not.
We only tech the top 3 after the main.
If you are cheating and can't finish in the top 3 then you really really really SUCK BAD......
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 11-25-2008, 06:57 PM   #17
carbon madness's Avatar
Originally Posted by baw888 View Post
Thats a great idea! There was a rule in speedway out here in Aus that was similar. If you won the night you motor was up for sale if anyone wanted to buy it. Made for some very even motors and racing!! Maybe you could use a similar rule?
That is a lame rule, yes it will make even racing, but if the guy who wins doesn't have much money and can't buy a new motor then they will not want to race anymore.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 11-25-2008, 07:09 PM   #18
fiveoboy01's Avatar
Trader Rating: 17 (100%+)
why do we want to keep it stock?????
Because it's cheap and affordable. The reason for the Slash's popularity.
brushless of your choice(look down for resons)
Disagree. A Motor/ESC combo costs more than the entire RTR truck does.
MIP, RPM and traxxas parts only.(any of there parts, so ball diff, CVs, etc are open)
I disagree again. My opinion is that it should be stock Traxxas parts ONLY.
NO ball diffs or CV joints.
shocks are up to you cus the stock ones suck, but you have to use the stock springs.
The shocks should remain stock except for the tops which are known to pop off. Spring changes should be allowed.
stock servo.
I'm torn on this, the stock servo is cheap and affordable, but I am not against allowing any servo you want either.
everyone uses the same compund foams.
I'd rather see no foams... Rubber tires only. Guys who want to race in the dirt as well come springtime will not have to have two sets of tires.
how are you going to inforce it? spec each car after every race?
Cars get inspected before racing starts, and possibly the winner's cars after the night is over or if someone protests. Of course I'm sure that the racers will police themselves, if someone sees anything illegal they're encouraged to let someone know about it.
there is no way a stock slash is going to clear that tabletop
There is no NEED to clear the entire tabletop.
Here's a hint: From what I see, a lot of the fastest guys land on the tabletop...
RCP has the spec class covered.
RCP doesn't HAVE a slash class to my knowledge. Besides, we are not RCP.
its only a little more to run brushless than a stock motor
False.
if we keep the stock motor, racing will not be equal, whoever has the newest motor, broke it in, and made some "shady" mods, corectly will be the fastes, IDK about you but I don't have the $$ for an new motor every other weekend, were as a brushless can be had for under $130 now and you can sell the stock motor/esc on ebay for $40 anytime, somtimes more.
I just don't buy that argument. If someone wants to go to those lengths fine, but I don't see anyone doing it. And even if they do at least they're limited to the Titan motor.
I will say this, if we decide to use a brushed motor, my slash will be for sale the next day and I will buy a T4
And that's your choice, nothing has been decided, I'm not even a decision maker. I only started this thread to get an idea of what other clubs were doing.
By the way, a properly outfitted and competitive T4 is going to cost you a LOT of $, a WHOLE LOT more than a Slash
Bill
JR Vibe 50, and that's it!
fiveoboy01 is offline   Reply With Quote
Old 11-25-2008, 07:19 PM   #19
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Are track is up to 19 plus trucks a week and 25 this week with more guys coming each week.
Are rules are fairly simple. You can change the receiver so you can use any radio.
You can change anything that is given to you in the kit. Shock oils, pistons, shock spacers. You can run the Slash body or Proline Slash body. Any gearing and any 2S lipo under 5300 mah. Everyone runs the stock motor. Stock tires and rims are to be used.
It makes teching easy and keeps racing cheap.
We are looking to do a pro class. Only change is to keep everything like I posted above but any brushless system. This way will have a slower spec Slash class and a Pro Spec Slash class.
ST Racing Concepts (STRC)
Old 11-25-2008, 07:50 PM   #20
whitrzac's Avatar
Trader Rating: 96 (100%+)
a havok BL combo is $130
I can see no ball diff and cv joints, but why not RPM parts?
and the steering bellcranks bind without bearings
then you loose the awsome body roll that makes them fun to drive.
maby slash style/ duel rate springs only? hot racing makes a spring kit for the slash...
I don't think that it would make any diffrance, with rubber tires your not going to get enough grip to turn anyway
ok, thats going a bit far, $40 for a set of wheels/tires...
of course there is, so I can cartwheel around the next turn
I thought they did?
False.
ok, its a bit more to run brushless, but with brushless we could have longer mains...
if we do stay brushed, please don't use the stock titan, us somthing like a spec 19t that is rebuildable and has BEARINGS
but, but, but, damn, can't think of anything
btw, a slash with a reedy 19t quad mag seems to have the right power
whitrzac is offline   Reply With Quote
Old 11-25-2008, 08:06 PM   #21
zraaron's Avatar
Send a message via AIM to zraaron
no no no. The brushless or brushed motors don't determine how long you can run. Its the capacity of your battery. Sure some motors are more efficient than others but somebody running a brushed motor with a good lipo will outlast somebody with a brushless on a 6 cell nicd.
zraaron is offline   Reply With Quote
Old 11-25-2008, 08:07 PM   #22
TwoTone's Avatar
Whit
You are just plain missing the point. Your set of rules would kill the Slash faster than anything else.
The Slash works as a spec class cause it's cheap.
The minute you change that, people might as well run in the other classes they already run in.
TwoTone is offline   Reply With Quote
Old 11-25-2008, 08:11 PM   #23
whitrzac's Avatar
I still think it should be brushless...
Originally Posted by TwoTone View Post
Whit
it still is cheap...
besideds, a VXL slash can't be that far away.
Old 11-25-2008, 08:14 PM   #24
tschenck's Avatar
Trader Rating: 110 (100%+)
You can change the receiver to run what ever radio you want. Other then that you can change shock oils, spacers, gearing and the body. Battery is 6 cell nimh or 2s lipo.
Must have stock motor, esc and servo in order to keep the class cheap for everyone.
Pro-Line/MIP/Team Scream Racing/Dirt Skins
Wolcott Hobby/RCHR
Losi 22 4.0 hobbywing xr10 pro stock spec, tsr 17.5
tschenck is offline   Reply With Quote
Old 11-25-2008, 08:30 PM   #25
Default South County Park, Boca Raton Florida
Box stock, Factory assembled stick pack, unmatched only. If it did not come in the box it is illegal, that goes for radio system too. Why? Because that way Dad and son, and mom too for that matter can drop 200 bucks and race competitively right out of the box, remember, economic times are hard and going to get harder, we want to keep it affordable and keep them racing each weekend. Thats how we run it and its good close racing, fun to watch and we get new blood each weekend.
boyntoncyclone is offline   Reply With Quote
Old 11-25-2008, 08:41 PM   #26
TwoTone's Avatar
How are those 4 truck heats? Sorry the radio rule is over the top.
Old 11-25-2008, 08:42 PM   #27
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
At some tracks there is the regular Spec Slash class and then an open or mod Slash class. Whit , You must not have been around back when stock racing was popular . That was the best class back then IMO .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-25-2008, 08:50 PM   #28
whitrzac's Avatar
I cought the tail end of it what ever happend to "stock" racing? didn't a few people decide that they were going to make there car go faster anyway that they could? ruining the racing for everyone else, because its no fun being laped 4 times when last week it was an even race...
Old 11-25-2008, 09:01 PM   #29
Hey TwoTone, how long you been around RCing? We have been swaping the AM crystals around to make the + radios since the late 70's when the FCC gave us the CB channels!!
Swap them crystals around and watch our 8 Slash heats!!
"Experience is the best teacher, and is best learned from others experiences"
"Just because I HAVE to grow old, does NOT mean I have to grow up!"
MaxAmps...Novak Brushless...Yokomo...Robitronics...Kawada...OFNA/HoBao...ABC...Hot Bodies...Schumacher...
Da Wizard is offline   Reply With Quote
Old 11-25-2008, 09:06 PM   #30
TwoTone's Avatar
LOL you're the one that said if it didn't come in the box... that goes for radio too.
Thunder RC Raceway - Nashville TN nashrcracer Georgia Racing 110 04-23-2013 08:59 PM
Chicago Area Electric Racing Talk chicagokenji Wisconsin & Illinois Racing 357 04-22-2011 09:40 AM
SLASH CLASS LOVE IT HATE IT? li racer Electric Off-Road 475 05-21-2010 10:34 PM
Idea's for changes to the 2009 JBRL series J-Mal Electric Off-Road 60 12-09-2008 03:16 PM
Racing your Slash 1995_corvette Electric Off-Road 15 12-05-2008 11:12 AM
Which one to buy slash or losi desert truck? washracer Electric Off-Road 36 06-27-2008 03:54 PM
