Old 11-15-2008, 12:22 PM   #1
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Default Brushless problem
I have had a Novak 10.5 for a few months now that I bought used . Last time I ran it I thought I broke a gear from the way it was making this noise and not moving well . I checked everything and ok . It`s been a few weeks since then and was getting everything ready to race tonight . I put a battery in to make sure everything was ok .
Well , it`s not ok . Seems the motor is cogging at low and higher rpms and doesn`t get to the high rpms it used to . I checked the motor and reset the ESC and same . Also sometimes the motor won`t spin unless I manually spin it to get going . Any ideas ? Is this a motor issue or ESC issue ? Thanks for any help .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-15-2008, 12:43 PM   #2
Shark413's Avatar
Trader Rating: 24 (100%+)
Hi, doesn't the ESC have some led lights? and if so, I think they may tell you what the issue may be. I had a Novak HV system a long time ago and I had a similar issue, the led's indicated a "locked rotor" error and when I contacted Novak they said I had to send it in for repair (ESC). I would contact Novak and get there feedback.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 11-15-2008, 12:54 PM   #3
adawg1's Avatar
This might be a dumb thing to think of but mine cogged because of the ecs being to close to the reciever or anntena.
XXXT Losi with velineon vxl brushless motor and 5000 venom lipo
Revo with xtm .32
Ofna buggy with Picco .32
adawg1 is offline   Reply With Quote
Old 11-15-2008, 01:00 PM   #4
Briguy's Avatar
Mine is on the opposite side of the truck .
Royal R/C & Hobby
Old 11-15-2008, 01:32 PM   #5
Trader Rating: 95 (99%+)
You need to get another motor and check it with that speedo. You don't mention what brand the speedo is.... If a GTB there is a remote possibility that your power cap is bad. But to be perectly honest I had a novak GTB do exactly what you describe. It was toast. They didn't tell me what happened to it or what caused it, they just replaced it.
Mine was running fine out on the track and just went to crap also.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 11-15-2008, 01:37 PM   #6
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
Have a 3.5 that acted like that, pinion end bearing was bad.
It also was a used motor.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 11-15-2008, 06:16 PM   #7
Briguy's Avatar
Has a new bearing in it . Yes it is the GTB and I emailed Novak so hopefully they have an answer . I`m not going to buy another motor and then find out the ESC is shot . Doesn`t the leds light up a certain way if the esc or motor is toast ?
Royal R/C & Hobby
Old 11-15-2008, 06:42 PM   #8
Mine "lit up" as if it was all normal even though it didn't work. Call up a buddy and borrow a motor just to test. At the same time have them hook up our motor to their speed control and see how it runs.
Old 11-17-2008, 11:36 AM   #9
Briguy's Avatar
I put in a brushed motor and ESC works fine . So guess it`s time for a new brushless motor . Thanks for all the replies .
Royal R/C & Hobby
Old 11-17-2008, 11:51 AM   #10
gndprx's Avatar
Trader Rating: 18 (100%+)
I've sent 2 systems in over time for similar issues. One was ESC, one was Motor.
Best option is to send it to Novak and let them look into it. That's likely what they will suggest anyway.
gndprx is offline   Reply With Quote
Old 11-17-2008, 01:09 PM   #11
Krio's Avatar
Trader Rating: 150 (99%+)
Sounds like you are missing a phase. If you can spin it to get it going it will still run on the other two, but like you found it will cog low and won't rev. This can be caused by a faulty sensor in the motor, the sensor wires being broken/not plugged in, or the worst case is the esc lost something inside. Like everyone has said, try to find another motor to try and that will determine if its the motor or esc.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-17-2008, 05:41 PM   #12
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Had the same problem with another brand of ESC. They all work on the same principle.If the sensor cable/array on the motor is ok, you're right, it is a bad phase in the ESC. The horrible noise comes from the motor suddenly stopping and starting again. I could actually feel my 2wd buggy kick when I held it in my hand.
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-17-2008, 05:50 PM   #13
Briguy's Avatar
Endbell of the motor all I could remove was the black plastic plate and couldn`t see if the sensor wires were ok . Waiting to hear back from Novak but might just get a new ESC and motor anyways . I don`t want to be waiting a few weeks to race . Also , if there is a bad phase wouldn`t it affect when running a brushed motor ? Is there a way to test to see if all three phases are working ? Besides trying another motor .
Royal R/C & Hobby
Old 11-17-2008, 06:25 PM   #14
I'm just making an educated guess here. Seeing how the wiring is done when using a brushed motor with a brushless/brushed ESC you may not notice as much of a problem. When the ESC is re programmed to run brushed it runs the FETs differently. When you rewire the ESC to run brushed, all three phases are paralleled to the negative motor terminal. The two good phases may make up for the lost phase. The only problem you may notice is extra heat, and possibly lower run times.
Three words...
Old 11-17-2008, 06:46 PM   #15
Trader Rating: 20 (100%+)
I had a similar problem with my 13.5. put a different motor in and all was well. Later on i noticed i had a sensor wire on the plug end that seemed like it broke. haven't tried to fix and run yet. Took the motor apart and it looked all good. idk
SnakeBait is offline   Reply With Quote
PERTH RADIO ELECTRIC CAR CLUB gforceracing67 Australian Racing 927 06-16-2017 01:57 AM
HPI Super Electric RS4's W/Brushless system Silver Cup Oval, Larger Scales and More 671 05-15-2017 11:28 AM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 839 11-01-2011 04:31 PM
RRCSA Electric Racing at Littlehampton, South Australia Swanny Australian Racing 1229 10-01-2011 06:44 AM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
2008 R.O.A.R. ASPHALT NATIONALS (UPDATED INFO THREAD) mrrcguy Electric On-Road 1297 08-23-2008 11:54 AM
Brushless Motor Thread RC Buddah Electric On-Road 261 08-30-2007 03:42 PM
