Old 01-12-2009, 06:58 PM   #91
RCBLUE's Avatar
Originally Posted by RC nut View Post
I have an adult stupid question ... Can you mate any sensored brushless to the RS Pro? I'm bashing with a Novak Havok 8.5 / 2s Lipo 8000, 14/87 gear and after 20 minuets of hill shooting and jumping a cuple 5 foot mounds of sand runing sand paws the ESC . I wouldn't think with that gearing it should have done that... or am I asking to much from the ESC with that combonation and just need to add a fan?
It sounds like you are way under geared. I have a RSPro with a Redline 13.5 and I'm geared at 26/81 on my T4. What truck are you running?
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 01-12-2009, 08:40 PM   #92
T4... I read somewhere here on the forum that Novak recommended twice the wind for a pinion. So going by that formula I need to go up for sure a few teeth. I figured sense I was running the Sand paws and bashing in sand that the 14/87 would be a good combination considering tire hight and load. sorry didn't mean to jack the thread...
RC nut is offline   Reply With Quote
Old 01-12-2009, 08:55 PM   #93
yodace's Avatar
R/C Tech Charter Subscriber
Originally Posted by whitrzac View Post
yodace: do you have a cap on the esc?
RC nut: is the gearmesh set right? any binding in the trans? also, try gearing up by a cupple teeth, the esc gets hot from runing at WOT all the time.
yes the stock one
yodace is offline   Reply With Quote
Old 01-12-2009, 09:34 PM   #94
RCBLUE's Avatar
I would still start to gear up. Check your motor and esc temps about every 3 minutes of hard running till you get it close.
Serpent America
Lunsford Racing
Old 01-12-2009, 09:39 PM   #95
I'm going to step to a 16 as soon as I get my parts and give it another go.
Old 01-14-2009, 04:08 AM   #96
Novak GTBs finished 1st and 2nd in a 45 minute 1/10th scale truck race at the RC Pro Series Nats in Texas back during November...the only 2 Novak powered trucks in the race and 1 did not even use the fan on the ESC.
A true test for reliablity and speed on an 1/8th scale size track with huge jumps and bumps.
Novak is hard to beat for reliablity and the customer service is the best in the industry!
Tired of high priced gasoline!
Go here to help out: http://www.americansolutions.com/
Craps is offline   Reply With Quote
Old 01-14-2009, 06:25 AM   #97
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
Novak - GTB with Lipo cutoff. Works fine never had an issue with it. However, I do not feel the programming changes and I've owned over 4 GTBs before I switched mostly to LRP due to size since the GTB has a large footprint. I have crossed the +, - wires with the power off on the speedo and I didn't fry it. I would have to agree the Novak Customer Service is great and they are very helpful.
LRP - Programming changes are noticeable and is fairly easy to program once you do it a few times. I use the TC Spec the most. Do not cross the wires or you'll fry this speedo even with the power switch in the off position . Customer service is ok, a little slow to respond to e-mails but the do get back to you.
Tekin - RS Pro, based on the reviews on here, I want to try it out.
KO/Orion - I also want to also try the KO Brushless speedo that also has a small size and similar-styled soldering posts like the Tekin. It also has a PC interface for more in-depth tuning.
Does anyone use the KO or Orion brushless ESC?
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
