LiPo query
#16
Check the Orion 2400 and 3400, maybe the 3800. They have rounded corners just for the reason you state. There are others too.
#17
Tip: In the case of the Castle motors, the name/number designation 4600, 5700, 6700, etc. are the motors "kv" which means 1000's of rpm (the "k") per volt (the "v") so if you look at the 5700kv motor, that thing will spin over 60k rpm on 11.1 volts, over 40k rpm on 7.4 volts. Have a look at the 4600kv motor, with modern batteries you'd need a really high traction surface to harness much more power than that.
If you're new to RC, especially racing, you will enjoy yourself more with less power. It's tempting to get the fastest stuff (it doesn't cost any more, right?) but you will be frustrated at how hard the car will be to drive and most likely lose interest than if you get something that you get around the track more easily when starting off.
#19
Thanx dudes, you`ve been pretty helpful
#20
The guy is on a budget & drives a mad bull. A 30 step throtle curve instead of a 100 step curve isn't going to make a difference. Here is what I would get on a budget.
http://cgi.ebay.com/eZrun-RC-car-Bru...1%7C240%3A1318
Then purchase
http://cgi.ebay.com/Hot-Power-Li-Po-...1%7C240%3A1318
That stuff will run you about $200 total.
Then purchase
#21
you can also get that stuff here, not sure whose shipping is cheaper.
http://www.rcmart.com/catalog/rc-bat...?cPath=52_1271
#22
Now that helps
#23
MaxAmps Fans,
For the next 48 hours you could save over 50% OFF of our most popular packs depending on your membership discount. Get FREE 3 year 300 cycle warranties and FREE skins on every lipo pack we offer. This is our biggest sale ever!
6000HV 7.4V pack- $99.99 plus free warranty and skin(normally priced at $154.48) http://www.maxamps.com/Lipo-6000-74-Pack.htm
Above discounts are in addition to your normal membership discount of 5-20% off!
Check your membership discount by logging in
Sale ends on Tuesday November 18th at Midnight!
-The MaxAmps Team
www.MaxAmps.com
-The MaxAmps Team
www.MaxAmps.com
