Old 10-02-2003, 04:39 PM   #1
TSB
Default MST-1 Setups
What are the setups that everyone is running? Has anyone tried limiters? How did they work?
This is what I am running at TRCR (grey clay)
Front-
Camber link- long
Camber- 0 degrees
Shock middle on the tower/ middle on the arm
20 weight - silver spring
1.5 piston
two small shims under the rear of the front pivot block
1 losi #4 gold washer under the bulkhead ball stud
blade- m3 - trinity bomb one grey foam
Rear
Camber link-
tower- upper inside
hub- inside
2 degree hub
4 degree reqar pivot
one #4 gold washer under front pivot block
shock- out side on the tower - inside on the arm
30 weight
1.6 piston
white spring
bones level
hole shots - m3 - trinity bomb one grey foam
I need more traction in the rear and still be able to maintain the steering that I have for the tight track I am racing on.
TSB is offline   Reply With Quote
Old 10-03-2003, 12:15 AM   #2
wild gopher's Avatar
Trader Rating: 39 (100%+)
thats about the same setup I run except for the rear hubs- 1 degree, and all shocks bored to 1.5 using 20wt in front and 25wt in rear. Im not sure about your rear traction but hard clay might use smaller pin tires- maybe the new proline R series. My local track is a soil/clay combo that is hardpacked but after 1/8 scale buggies tear it up there becomes a fluffy top layer that kills my rear traction with the bowties.
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 10-03-2003, 10:57 PM   #3
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
wild gopher- do you race at Revelation?
Racing4Evo is offline   Reply With Quote
Old 10-04-2003, 12:10 AM   #4
cant say that ive raced there but im there every thursday night usually with my savage and mst-1. I plan on racing on a regular basis there now that my confidence got a major boost from the savage slam
gti setups infernoman2008 Nitro On-Road 3 07-09-2008 01:57 PM
B44 Setups Rorynw Electric Off-Road 0 10-08-2007 12:29 AM
TC3 Setups mach51 Electric On-Road 8 12-09-2006 10:56 PM
tc3 setups andrew5 Electric On-Road 4 01-30-2003 08:07 PM
