Old 11-09-2008, 07:11 PM   #1
Default XXX-T MF1 gearing question
I am new to brushless stock truck and am trying to figure out what to start out at. Thanks for the help
stoopideric is offline   Reply With Quote
Old 11-09-2008, 07:23 PM   #2
That Mf1 has the 1st generation tranny which gives it a 2.43 ratio
Depending on Spur , You want to have roughly a 7.5 FDR (final Drive ratio)
I use 7.5 Fdr because I use a novak motor, But I have used this for my son 17.5 speed passion also. So this is what I have set up 82 Spur/26 pinionx2.43
I have geared down to a 25 for a little more torque on a technical track.
Then I have ran a 86 spur/27 or 28 x 2.43 for another set up. You also can try a 78 spur /24 pionion x 2.43 combo .
Dynodan22
dynodan22 is offline   Reply With Quote
Old 11-09-2008, 08:15 PM   #3
Trader Rating: 23 (100%+)
im running a 82t spur with a 28t pinion. works good.
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
