Old 11-09-2008, 09:27 AM   #1
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Default Going to build a Losi Diff...what do you recommend?
I have a Speed-T I am going to run off-road. I want to know what to order for the diff grease that works best, and where to get some good 3/32 Ceramic diff balls....I remember reading 1 place had 1$ a piece I think, but was not sure....
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 11-09-2008, 09:33 AM   #2
The Bfastrc diff is the best. Get the gen 1 pro drivers kit, AE black grease for the thrust assembly and AE silicone diff grease for the diff gear.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 11-09-2008, 09:47 AM   #3
y2kgtp's Avatar
These 2 then?
ASC6588 - Team Associated Black Grease, 4cc
ASC6636 - Team Associated Differential Silicone Grease (4cc)
Was thinking these for balls:
http://www.avidrc.com/shop/?action=i...=6&prevstart=0
Old 11-09-2008, 11:41 AM   #4
ms3 Chris's Avatar
I suggest an Associated Diff Gear, Rings, Outdrives, thrust/diff balls, bearings and associated silicone/black grease...ok, maybe that wont work, but it will be a smooth diff
Chris Shieldsmith
Hot Bodies Racing www.hotbodiesonline.com
Tekin www.teamtekin.com
Team Checkpoint
ms3 Chris is offline   Reply With Quote
Old 11-09-2008, 12:12 PM   #5
nsane's Avatar
I'll second the BFast kit, it doesn't use ceramics, but the rings and balls included work very very well. I've been quite happy with the performance in my XXXT-CR.
Tekno e-D8 (build in progress)
Kyosho Lazer ZX5 SP
XXX-T CR
http://www.ncchampseries.com
nsane is offline   Reply With Quote
Old 11-09-2008, 12:23 PM   #6
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
Y2K - Honestly, you can build a very good diff that lasts a reasonable life from the stock Losi parts. The Losi carbide balls work fine. The stock thrust assembly works good as long as you don't overtighten it and crush it during assembly. I've seen alot of people use the AE black grease on the thrust and the AE silicone diff lube on the balls. That works fine, although I've had alot of luck with the stock Losi grease as well.
Good luck on your diff build!
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 11-09-2008, 12:41 PM   #7
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
i would recommend the losi thrust washer setup, losi part number was losi3098 a couple years ago. Lot easier than the thrust ball setup.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 11-09-2008, 12:54 PM   #8
Gliptal's Avatar
I've been using the losi carbide balls in my B4/B44 and they work good, smooth and last a long time. I've used ceramics in the past but they didn't work any better or worse than the carbides.
Normally for a rebuild I just replaced or flip the rings and slap some new balls in. The thrust assembly, at least on the AE cars, last a long time.
Gliptal is offline   Reply With Quote
Old 11-09-2008, 09:58 PM   #9
y2kgtp's Avatar
Ok...I'll check out www.BFastRC.com then.....
Old 11-09-2008, 11:32 PM   #10
Rockpyle's Avatar
The axiom ceramic diff balls and thrust bearings are great.
http://www.axiommotors.com/diff-rebu...lls-p-480.html
Rockpyle is offline   Reply With Quote
Old 11-10-2008, 06:17 AM   #11
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
The Pro driver kit from Bfast is the way to go . I`ve been racing many years and never had a diff feel as smooth theirs .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-10-2008, 06:34 AM   #12
badassrevo's Avatar
The B Fast diff is the smoothest longest lasting diff on the market.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 11-10-2008, 08:59 AM   #13
y2kgtp's Avatar
I have been Emailing them.....likely will order one
Old 11-10-2008, 10:20 AM   #14
action135's Avatar
like what was said before, you can just use the same stock losi stuff with a little tlc and keep a good smooth diff.
the only things i've changed from when i got the kit two years ago is a traxxas ball assembly for in the outdrive and brass shims for the diff rings.
just make sure when you rebuild your diff you sand your rings good and smooth. you can either wet or dry sand them.
i usually use a medium grit emery paper to knock any burs off, then finish with 600 grit paper. super smooth diff action is a result.
but taking the bearings apart and thouroughly cleaning is a good idea as well
action135 is offline   Reply With Quote
Old 11-10-2008, 10:53 AM   #15
They have a thread on electric offroad. It is on the 2d page of this forum I think.
