Old 11-03-2008, 09:57 PM   #1
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Default Bearings....anything to free up new ones?
Just curious if anyone has some tricks to free up stock bearings? I remember cleaning then out with brake cleaner and a drop of WD40 in the old days....but not sure if any 'tricks' still apply?
"Yes my car is technically illegal, but still its either just as fast or slower than any other car on the track so whats the issue with it being illegal?"
y2kgtp is offline   Reply With Quote
Old 11-03-2008, 10:08 PM   #2
Use motor spray/nitro cleaner with RPM bearing blaster to clean the bearings and Trinity bearing oil for the motor/tranny and 3 in 1 oil for the wheel bearings.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 11-03-2008, 10:23 PM   #3
Timmahh's Avatar
Send a message via Yahoo to Timmahh
you can pop a seal off, flush out with wd 40, re apply the seal after regreasing.
TeamFastEddy.com sells a unit called the Greaser. its a bearing greaser that you can use with the seals inplace. its really quite a nice lil unit and can do many sizes of bearing used on most all our RCs with exception to some of the largest bearings found in the HPI Baja 5B diff (Big Bearings).
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 11-04-2008, 12:43 AM   #4
JeromeK99's Avatar
You can blast all the grease out of a bearing or soak it in motor spray and then use oil... only problem is that you have to do it often or they blow out.. Yes.. oil is smoother than the grease in most steel or carbide ball bearings.
All bearings are not made equal... when a bearing is new, they are usually pretty good... but as they age, that is when you can really tell..
You can buy decent quality bearings from the car manufacturers, but they are usually really expensive if you look at them closely. Avid sells most of the same bearings for a buck a piece! You could buy a set of Ceramic Bearings from companies like BOCA (i have had them last 4+ years! but at $140+ a set) or run some of the less expensive brands like ACER. Still really smooth at about half the price. You can definatily tell the difference running a ceramic bearing set over standard. The car gets going much faster and smoother.
As long as you don't run in water or mud, you shouldn't even have to oil a good ball bearing... That one thing that cracks me up about some newbs running Traxxas Slash Trucks.. they if you tell them don't run in water.. they all say "It's water proof!"... well.. maybe the elctronics... but what about the bearings? Then again.. just buy a bunch of Avid bearings at $1 each.. then it doesn't matter.. lol
Have fun!
Jerome
JeromeK99 is offline   Reply With Quote
Old 11-04-2008, 06:53 AM   #5
y2kgtp's Avatar
Thanks for the replies....maintenance time is not an issue....I was just looking for a bit smoother....or better spinning bearings out of the stocker ones.
Old 11-04-2008, 06:58 AM   #6
macr0w's Avatar
Have fun!
Jerome
That's what I say. When they get slow, pull them out and chunk'em.
www.clearspotrecording.com
macr0w is offline   Reply With Quote
Old 11-04-2008, 07:04 AM   #7
y2kgtp's Avatar
I just might get a few items from Avid now....
Are the ceramic bearings that much smoother? I would think so as most seem to run ceramic balls in the diffs alot.
Old 11-04-2008, 07:59 AM   #8
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
if you pony up and go ceramic you wont believe what you've been missing all these years...but it is an investment in both money and maintenance. You cannot afford to slouch on your bearing maintenance if you're running ceramics. If you have a ceramic bearing set, dont mess around with taking the grease out of them, they need to be broken in and let them do their thing.
Avid yellow seals are awesome bearings for the price, outfit your car for under $30 and they're pretty free.
One time, and this is before I had a life haha....I took the seals off my bearings, took all the grease out so they were dry, then packed the bearings full of mothers metal polish and re-installed all the bearings back into a "dummy" transmission case and chucked the top shaft into a drill for 10 minutes...took all the bearings out, washed them off with simple green and swear to god I had like 2 minutes of free-spin w/ the wheels on. My bearings detonated after 2 runs, but dammit my car was fast!
I just got a new B4FT and am running kit bearings, they're plenty smooth for the time being. I will upgrade to the B44 hubs/bearings in the back as I blew-up a hub bearing at my first race, but thats common. Down the road, my next bearing upgrade will be a full-on Boca Orange Seal (level 7) or whatever they call it ceramic kit. Yep, they're about $140 for the whole kit but a better bearing does not exist.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-04-2008, 08:03 AM   #9
y2kgtp's Avatar
Do they have kit prices, or do you need to go threw the manual and figure it out bearing by bearing for what you need?
Old 11-04-2008, 08:07 AM   #10
www.bocabearings.com
they have a different level kits to choose from.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 11-04-2008, 02:22 PM   #11
y2kgtp's Avatar
Thanks....I'll give it a look.
I would be looking for a stadium truck set, so should not be TOO expensive, I would hope.
Old 11-04-2008, 04:33 PM   #12
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Just replace with avid bearings. I am loyal avid buyer they are top notch service.
I keep lots of spare bearings with me. they are very important to change and replace.
well if you race alot.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 11-04-2008, 04:37 PM   #13
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
u could get 5 bearings from dave for price of 1 ceramic. u will NOT notice a difference on ur stadium truck at club races. check that...you will...
...when 1 of them crunches and ur now down $5bux and a bearing.
onroad yeh, go ahead, but add dirt and jumps. no way
R
UltegraSTI is offline   Reply With Quote
Old 11-12-2008, 10:48 PM   #14
Trader Rating: 27 (100%+)
Is the RPM bearing blaster worth buying. Does it clean gritty beatings?
jjdoyle is offline   Reply With Quote
Old 11-12-2008, 11:08 PM   #15
RCBuddha's Avatar
As others have said, if you want your bearings to spin free, remove the grease from inside of them, and then use a light oil. Its a lot more maintenance, but it will result in a freer drive train.
I've even seen drivers who will keep half of the bearing de-shielded (one side open) allowing for easier maintenance.
I've had mixed results with it. I prefer to soak, then spray mine on top of a towel. YMMV.
RCBuddha is offline   Reply With Quote
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15109 10-10-2017 05:01 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Offroad Nitro Engine Forum 97 01-07-2014 09:43 PM
Losi BK2/MF2 thread DerekL Electric Off-Road 2850 07-18-2010 11:59 PM
Big Revo parts sale Plus other stuff! jldjlaudio R/C Items: For Sale/Trade 7 12-19-2008 10:21 AM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 10:03 PM
Various R/C Vehicles for sale. Thai3g_Eclipse R/C Items: For Sale/Trade 34 04-13-2008 08:13 AM
