Associated T4 Setups Only
3 piston 35 wt.3limiters front Gold springs
1 piston 30 wt. 3 limiters rear Green springs
middle on front tower outside on front arm
inside on rear tower inside on rear arm
front link inside on tower inside on caster block
rear link inside on bulkhead and middle on rear hub (Bulkhead grinded flat with 3 shim added.) Add or remove to loosen or tighten up the rear.
Front hub forward
Rear hub middle
1 1/2 ounce in standard position (under bulkhead and 1/4 oz on each side of battery.) !/4 ounce inbetween front arms.
-1 deg. camber around.
0 deg. toe
0, deg. anti-squat. (play with these shims depending on your layout)
rear bones slightly above level
front arms bout level.
Try it out !
Front hub forward
Rear hub middle
0 deg. toe
Try it out !
Any good setups for asphalt? I'm running 2.2 Jaco foam tires on stock setup.
Jim told me to use Ryan Cavalieri's setup from when he raced at Milwaukee.
So go to www.RC10.com go to racing, then setup sheets. Click on T4 and all of the setups will be there.
