Old 11-01-2008, 03:03 PM   #1
Krio's Avatar
Trader Rating: 150 (99%+)
Default Exact size of novak's "oversized" bearing?
Had a bearing finally wear out in a 5.5 novak and have already replaced it with a new endbell kit. I have since removed the bearing out of the old endbell with the hope of replacing it for a backup. Anybody know the exact dimensions on the oversized endbell bearing?
www.kriostasis.com
Krio is offline   Reply With Quote
Old 11-02-2008, 08:23 PM   #2
Krio's Avatar
anyone?
www.kriostasis.com
Old 11-02-2008, 09:38 PM   #3
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
um... digital verniers ( calipers ) ftw?
NJA82 is offline   Reply With Quote
Old 11-03-2008, 11:32 AM   #4
Krio's Avatar
Yeah, a good set of digital calipers are still on my "to buy" list
www.kriostasis.com
Old 11-03-2008, 01:39 PM   #5
ta_man's Avatar
Trader Rating: 151 (100%+)
You don't need calipers. These bearings are standard sizes. You could measure it with a ruler graduated in 1/16th of an inch and come close enough to get the correct replacement.
ta_man is offline   Reply With Quote
Old 11-03-2008, 05:29 PM   #6
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
http://www.rctech.net/forum/4973331-post6.html
If you check your original oversized bearing, you'll see R3Z marked (mine had) on the metal shield of the bearing.
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 11-03-2008, 09:12 PM   #7
Krio's Avatar
That is exactly what I'm looking for. Thanks for responding.
Have a couple ceramic bearings headed my way.
www.kriostasis.com
