Old 10-29-2008, 09:53 PM   #1
Suspended
Trader Rating: 20 (100%+)
Default 1/8 brushless help
I'm converting my MBX5R into a brushless racer.
SPECS:
RC Product design motor mount and front bearing mount
medusa 036-60-2200v2 2200kv motor
axial battery tray cheap and it'll work
14T pinion 46T spur gear
Mamba monster max esc
Thunder power 18.5v 4600mah lipo
Here's my main concern. I have looked everywhere and have read different lipos used. How much runtime on a large 1/8 race track outside should I get. I'm hoping it's just over 20mins or I'm going to buy a bigger lipos.
Please help me...
bunnell33 is offline   Reply With Quote
Old 10-29-2008, 10:13 PM   #2
DickyT's Avatar
I get 30+ minutes track time with a neu 1515 1y (2200kv) in a converted 3.3 Revo running a Neu Power 14.8v 5000mah 25c. If your C rating is 20+ on that thunder power given the lighter weight of the buggy 20+ mins should be no problem.
If you already have the lipo, run it and find out. if you find yourself coming up short get a larger capacity.. If you don't already have it just get the larger capacity now and not worry about it.
I just bought an mbx5r roller to convert myself and will be throwing the revo gear in it. Enjoy it!
DickyT is offline   Reply With Quote
Old 10-29-2008, 10:16 PM   #3
Suspended
Thanks I'm hoping I can get about 22mins for the mains. I just bought a lightly used thunder power 18.5v 4600mah for just over $120 shipped thats half way. If this doesn't get me to 22 mins or atleast 20mins then I'm going true RC lipo 14.8v 8000mah, that'll get me there but DAMN $230 for it.
Old 10-29-2008, 10:30 PM   #4
20 minutes can be done. This is what I think determines the race time and here are a few factors to look at:
Gearing - Just be as fast as the nitro guys but not faster. This will help with run time cause you are not using more power then you need.
Driving style - Light with the trigger finger. Smooth is very important here.
Temps of the Motor, Battery and ESC. - This something you need to check on often till you see haw all of it going to play out over a 20 minute main. All the temps are determined by the gearing and driving style.
Good luck and have fun,
Joe
Joe Maxey is offline   Reply With Quote
Old 10-29-2008, 10:43 PM   #5
Suspended
Thanks.
Now can I put 2 lipos togther to make my runtimes longer. I thinking about buying the same exact battery, but a 3300mah. SO i'd be putting togther 2 thunder power 18.5v batteries 1 with 4600mah and the other 3300mah. Would this be safe and I would separate and charge/balance individually.
Old 10-30-2008, 07:57 AM   #6
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
your driving style will have a lot to do with how fast your drain the battery as well. Keep that in mind too.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-30-2008, 08:31 AM   #7
Trader Rating: 19 (100%+)
SPECS:
Please help me...
You should get right at 20 minutes with that setup. I can get right at 20 minutes of race time with a 5s 4000 pack in my rc8. The medusa isn't as efficient as a Neu, but 20 +/- minutes should be doable with your current setup.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 10-30-2008, 05:30 PM   #8
DickyT's Avatar
Thanks.
This is a bad idea, it would over draw the 3300mah pack. You want 2 packs of the mah and C rating when running multiples. you can mix voltages running in series, a 2s and 3s to make 5s, but parallel for extended run time you want 2 of the same packs with roughly the same cycles on them.
Old 10-30-2008, 06:22 PM   #9
Suspended
Ok yea I been reading alot about this online. That's pretty much I been reading. Thanks for the input.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28982 12-04-2017 11:08 AM
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18837 11-05-2017 05:29 AM
Bunbury onroad Taffyjnr5 Australian Racing 4025 03-18-2013 04:29 PM
4WD EP buggy jono mad racer Singapore R/C Racers 381 06-05-2009 08:47 AM
Electric Championship Tour (Rules and Schedule) No discussion. Exterminator Northwest Racers 31 02-01-2009 10:51 PM
