Old 10-28-2008, 11:21 PM   #1
Default affordable gps
Can someone please help me on some options on a small gps unit to record speeds on my rc's thanks ,.......
erevo, nue 15151y, mamba monster, 2p 5000 hv 11.1 maxamps/ losi 8ight mmm 1512 1.5,4s 5000mah ,slash mamba 5700 3s,baja 5b 29.5cc,associated sc10 mamba max pro 5700,slash 4x4 velineon,
erevo15151y is offline   Reply With Quote
Old 10-29-2008, 01:03 AM   #2
Drifting101's Avatar
I have a garmin if you get a basic one they cost about 75 bux second hand
and they are a very solid unit prolly the most solid on the market also they are light so they wont affect top end that much
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-29-2008, 05:07 AM   #3
Trader Rating: 21 (100%+)
https://buy.garmin.com/shop/shop.do?cID=142&pID=231
This is smaller than handheld Garmin - I use one for keeping track of exercise and saw a pic of one velcro'ed to an rc with speed displayed.
Downside is this one has little other use while handheld can do some other things.
Duster_360 is offline   Reply With Quote
Old 10-30-2008, 04:20 AM   #4
My auntie had one like that it is pretty un accurate.....the one i have is one for somethinag like orintering so it is pretty spot
Schumacher
Old 10-30-2008, 05:18 AM   #5
I've checked mine in the car for both speed and distance and as long as you drive for a few minutes, its is pretty much spot on. If you try real short distance, couple of hundred feet, maybe thats why. I'm happy with mine.
Where I saw it used for rc speed was on UE and the guy advised driving back and forth a few time before relying on what it was indicating.
Old 11-12-2008, 05:19 PM   #6
the garmin foretrex 101 updates at a rate of 1 hz... aka 1 time per second. so if you can keep the top speed of your car for at least 3-5 seconds, you should have a pretty accurate speed readout. what would be best is something that updates @ at least 5hz... or 5 times a second. but i haven't found anything in this size range and weight with this much accuracy
if you're interested in geocaching, i believe that you can add lat/lon coords as destination addresses, but the entry method gets tiring after awhile. also, this model does not link to a computer
yellow1 is offline   Reply With Quote
Old 11-13-2008, 12:10 AM   #7
Lol that is what i used it for when i said orientering....do you geocache?
Schumacher
Non RC item for sale. Land-Chaser Malaysian R/C Racers 27 12-10-2008 07:06 AM
