Old 10-27-2008, 01:02 PM   #1
Default Problems with Slash motor frying
Hey guys I'm new here so pardon my lack of knowledge.
I used to race back in the days (16 years ago) and have just started to get back into it.
I bought the Slash and decided to tweak it a little so I dropped in my Tekin
speed controll (I cant remember which model but its about 6 years old) and I bought a 7 cell Losi 4600nimh pack.
the problem I'm having is that I've fried 3 motors in the truck each one with a single charge on the Losi pack.
first I fried the stock motor (no surprise there) so I dropped in my Orion Chrome modified 15t double and fried it in about 9 minutes so then I tried my Komodo 19t and same thing it lasted about 12 min then got so hot it melted the solder joints.
I have been running that Tekin speed controller in my sons T3 for about 3 years with the same Orion chrome modified motor and have never had any problems until getting the Losi race pack. could that really be the problem or do you think it is a mixture of both ?
the speed controller is supposedly goodfor 4-10 cells and good to "no turn limit"
any help would be appriciated.
thanks guys
Jason
nolpegos is offline   Reply With Quote
Old 10-27-2008, 01:32 PM   #2
Miller_Time's Avatar
Trader Rating: 11 (92%+)
7 cell packs are definitely harder on a motor, that's probably the issue since you've also had problems with other motors.
It's also possibly a drivetrain binding issue. Take the motor out (or at least disengage the pinion from spur) and see how freely the transmission turns. You should be able to spin the wheels without much resistance.
I'd put money on it being the batteries though.
www.HobbyStop.com
Miller_Time is offline   Reply With Quote
Old 10-27-2008, 03:54 PM   #3
kufman's Avatar
The extended run times with newer batteries will cause more heat to build up in the motor. For trucks like the slash I would recommend not using high timing motors like the komodo, they just don't run very efficiently. The slash has the added problem of a plastic motor plate that doesn't help the motor dissipate heat. What pinion and spur gear are you running? You might need to gear down (smaller pinion) to keep motors alive.
kufman is offline   Reply With Quote
Old 10-27-2008, 11:09 PM   #4
Brandon A's Avatar
+1 on gearing down. Also, make sure your motors are nice and clean as dirty comms and gritty bearings are not helpful in keeping motors alive. 12 minutes is a pretty long time to run that setup so that might also be a contributing factor to your heat problem.
RCAmerica/Xray <> Panther <> RW Mods
Brandon A is offline   Reply With Quote
Old 10-27-2008, 11:37 PM   #5
Timmahh's Avatar
Send a message via Yahoo to Timmahh
ya gear it down maybe. ive been running the stock ESC (which is water proof and lipo ready with warning signal) and 7 cell 4200 packs without issue. not sure what pinion i have on it atm though.
Check my F/S ads I am posting up, Liquidating my bajas and SCBs in part outs.
http://www.rctech.net/forum/r-c-items-sale-trade/562290-wreckluse-crawler-chassis-other-scaler-parts.html http://www.rctech.net/forum/r-c-items-sale-trade/562534-hpi-baja-items-f-s-motor-rtr-tranny-full-wheel-sets-servos-more.html
Timmahh is offline   Reply With Quote
Old 10-28-2008, 04:28 AM   #6
Are you talking about the XL5 in the Slash? If so, is that a new update and when did they start that?
www.HobbyStop.com
Old 10-28-2008, 09:50 AM   #7
Timmahh's Avatar
yes. stock Slash ESC/Motor. 4200mah 7cell packs. im just not sure what pinion is on it. I ll ASSuME its around a 18T pinion.
Old 10-28-2008, 10:22 AM   #8
huskerdually's Avatar
I don't see anything about lipo alarm in specs?
huskerdually is offline   Reply With Quote
Old 10-28-2008, 02:43 PM   #9
JAM MaxAmps's Avatar
The stock esc (Blue Cased XL-5) is not A li-Po ready esc. There has been no updated version either. And stock out of the box gearing is 18/86.
This is right from Traxxas's site: ** The installed XL-5 does not provide low voltage detection for LiPo battery packs. Consult your hobby dealer for add-on solutions that will allow Lipo usage with the XL-5. Batteries sold separately. **
Jason
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 10-28-2008, 05:34 PM   #10
nexxus's Avatar
Trader Rating: 302 (100%+)
*Insert thinly disguised Max Amp plug for lipo cut off here*
You shouldn't be using Lipo in the slash anyway, it's a waterproof car yes, Lipos and water simply don't mix. I run my Slash on 7 cell Nimh only, no way will I run a lipo in it if I intend to get it wet (which is always)
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 10-29-2008, 07:47 AM   #11
It's perfectly fine to run Li-Po's in a Slash with a an LVC or an LVA. And water isn't good for any battery period whether NimH or Li-po. Packs can get splashed it's not going to hurt them at all. But submersion isn't a good idea and that goes for Both types. Simply put don't be put off by some who appears to be a bit biased about Li-po's. They are perfectly safe to use in any RC car. Oh by the way all I was doing was pointing out that the Blue cased XL-5 is not li-po ready. You simply turned it into a great plug thanks.
Jason
Jason
CMO
[email protected]
Old 10-29-2008, 08:35 PM   #12
air8's Avatar
JAM rocks. And so do the Maxamps batteries. There's your plug. LOL.
Anyways. A little confusion here on my part. I keep seeing the 18t quoted as being stock, but here on Traxxas' site it's showing 19t as stock with the 23t optional included in the box.
So is it 18 or 19 tooth stock pinion?
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-30-2008, 12:49 AM   #13
Trader Rating: 34 (100%+)
Arrow
I checked to be sure. Mine came with an 18T pinion with the 23T as the optional one.
don74 is offline   Reply With Quote
Old 10-30-2008, 06:54 AM   #14
I've got mine sitting here in my hand. I pulled it because I'm running a Mamba Max with a 7700kv on a 16T right now. Just counted the stock and it is 18T.
Jason
Jason
CMO
[email protected]
Old 10-30-2008, 06:53 PM   #15
air8's Avatar
Ok. Thanx guys. Just checking. Mine arrived at the LHS today but I have to work 12hrs tonight so I can't open it till tomorrow. Bummer.
--"U Ain't Fast!!"
Chris Pearce
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
