Old 10-22-2008, 02:15 PM   #1
JAM MaxAmps's Avatar
Default The New 30C 6500HC 7.4 volt pack
MaxAmps 30C 6500HC 7.4V Pack
MaxAmps.com presents the ultimate hard case racing pack. As you racers know, the most important factor for your batteries is voltage under load. This pack boasts a 30C constant rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other pack on the market. Plus, you’ll have no problem getting plenty of runtime with 6500mah of capacity.
• 30C Constant Discharge(195amps)
• Hard Outer Case
• 139mm x 47mm x 27mm
• 7.4 Volts
• 6500mah Capacity(plenty for racing)
As with all MaxAmps packs, you choose your plug, tap, and wire options and your pack is built to order within 24-48 hours of placing your order on the website at www.MaxAmps.com
Jason
MaxAmps Marketing Manager
jason[email protected]
www.MaxAmps.com
www.NitroKillers.com
Jason
CMO
[email protected]
www.NitroKillers.com www.MaxAmps.com Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 10-22-2008, 02:26 PM   #2
ta_man's Avatar
Trader Rating: 151 (100%+)
Will these be ROAR approved or is that just never going to happen because they exceed max dimensions for ROAR packs (being 27MM high)?
ta_man is offline   Reply With Quote
Old 10-22-2008, 02:47 PM   #3
hakmazter's Avatar
Thank you for making those. They will be absolutely perfect!
hakmazter is offline   Reply With Quote
Old 10-22-2008, 03:17 PM   #4
y2kgtp's Avatar
Trader Rating: 35 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Nice. I think I will go with MaxAmps once I start getting batteries.
After I get a truck.
If the wife gets me one for my B-day.
Maybe.
y2kgtp is offline   Reply With Quote
Old 10-22-2008, 07:08 PM   #5
RCSteve93's Avatar
ROAR rules state 25.1mm is the maximum height.
RCSteve93 is offline   Reply With Quote
