Power Supply?
Power Supply?
Can some one post me a link to a good 12v power supply I can use to run either 2 chargers or one dual charger?
I have been using a Hyperion 6 AC/DC charger. I'm thinking about stepping up to something a little better. But as you know most chargers use an external power supply.
i use the LRP 14amp Power Supply. Works like a charm and i run 2 chargers at the same time.
http://www.bulldawgrc.com/lrp14posu.html
www.buy-reliant.com
psv-300 30 amps @ $55.00
I have had mine for almost 2 years and it gets alot of use.
You can get same quality for better price as others mentioned .
I use this to power two chargers:
http://www.rcmart.com/catalog/rc-pow...ml?cPath=52_54
Works Great and a Great Price!!!
Great PSU. Been using it for almost a year now and no problems whatsoever. Got it primarily to power my cellpro so I can charge my 5s1p A123 packs at 10 amps. I've hooked up my cellpro with a 5s1p A123 pack at 10 amps and 2 orion advantage chargers charging 2s lipos at 4.9 amps. Only drawback is that the fan stays on all the time but if you are at an already noisy track who cares!
