Difference in armatures????
I am using a Komodo 19t motor. What is the difference in the armature that came with it and the Trinity 19T Pro armature you can buy for it and is there a difference in performance.
Pro is balanced and they cut the com. If you buy the Pro motor, they also shim it to better fit into the magnetic field.
Up to you really. I preferred motors from tuners though since they zap the magnets. Paul |
The Pro are usually the nicest arms to start with, and being balanced they have potential for more RPM's since the brushes won't float from the vibration.
