Old 10-29-2003, 08:06 PM   #46
Send a message via Yahoo to TambokGT
question:
When using the stock flywheel....do you guys have clutch springs? I am reading the RTR manual and it doesn't show about putting clutch springs.
TambokGT is offline   Reply With Quote
Old 10-29-2003, 09:15 PM   #47
I'm not 100% sure but you should have a spring wrapped around the shoes sitting in a groove. Without a spring the shoe will grab the bell as soon as the engine is lit (no neutral or idle).
AreCee is offline   Reply With Quote
Old 10-29-2003, 10:19 PM   #48
Kiiski's Avatar
The Associated clutch doesn't have springs, it seems to work fine, but I changed mine over to a MIP clutch w/spring.
Kiiski
And my 2 cents worth on the whole AE vs. Losi thing, in my opinion anyway, the Losi is easier to drive smoothly and is probably a better handling truck for a finesse type driver and the GT is better for the driver that has a more aggressive driving style. Yes the GT is tougher, but since we don't hit pipes or land wrong ever durability shouldn't be a problem.
Keep in mind also, and I feel this is a big issue, is what about parts availability. If your local hobby shop carries Associated parts and not Losi parts, then I would lean toward AE.
Kiiski is offline   Reply With Quote
Old 10-29-2003, 11:07 PM   #49
weird huh? During the tub chassis days...clutch springs were used. You are correct.....I don't understand the reason why they got rid of the springs.......the clutch would grab right away .....no idle.
Old 10-30-2003, 06:28 AM   #50
It may be weird but AE doesn't use springs in their clutch. I checked their site and confirmed it.
What makes this even weirder is that they use springs and have an optional spring for the NTC3.
Old 10-30-2003, 08:09 PM   #51
I heard the mIP clutch doesn't have a good idle and accerleration is poor......the best one is the AE 4 shoe....is this true?
To change PS to non PS: correct me if I'm wrong
I have to get the following parts
non pull start engine mounts
new mount for transmission
non pull flywheel
non pull manifold
......is this right? or did I miss something.
Old 10-30-2003, 09:19 PM   #52
KINGZJ's Avatar
Send a message via AIM to KINGZJ
The mip clutch works great and your list seems to be correct.
KINGZJ is offline   Reply With Quote
Old 10-30-2003, 11:08 PM   #53
KingZJ
whats your setup like in your MIP clutch?
Old 10-31-2003, 04:31 AM   #54
KINGZJ's Avatar
I run it trailing with no weights. I also have a mip heavy flywheel installed. You might have to stretch the spring a little, some of the newer clutches have a little to tight of a spring. Remember their is a breakin in period for the clutch so if its not perfect out of the box give it a little time. You will need to take it apart after a couple of tanks and make sure it is clean and fee of oil. Don't get any fuel on the bell either that will also cause problems. The heavy flywheel helps smooth out throttle transition it is very noticable, however it is not needed with high traction situations but those are rare with a nitro truck.
Old 10-31-2003, 07:39 AM   #55
Kiiski's Avatar
You don't absolutely have to have these items, though it does lower the engine a bit, lowering the center of gravity. I put an OS 12tr in mine and only had to change the manifold, mainly because it is a rear exhaust motor.
The MIP clutch works fine, I have never tried the AE 4 shoe, but have heard good things about it from a few people that come to my track.
Kiiski
Choosing a Budget Touring Car for Carpet Racing Cain Electric On-Road 41 11-08-2007 09:35 PM
Racing Electric Monster trucks with the nitro guys Cain Monster Trucks 1 06-08-2007 03:02 PM
Racing Monster Trucks, need info Cain Monster Trucks 8 05-14-2007 04:42 PM
xxx-t mf and xxx-nt racing trucks! Brandon R R/C Items: For Sale/Trade 1 05-27-2004 11:02 PM
Good place to run racing trucks? BloodClod Singapore R/C Racers 21 08-23-2002 09:44 PM
