Old 10-14-2008, 02:10 PM   #31
kufman's Avatar
The higher the "S" the easier it will be on the ESC if appropriate motor changes are taken into account. More voltage, less current = same power with less power lost in the ESC and wiring connections.
kufman is offline   Reply With Quote
Old 10-14-2008, 02:51 PM   #32
Trader Rating: 19 (100%+)
3s is not the ideal voltage. I ran a couple of races with 3s and a 1512 1.5d (3300kv). I loved the power, but the batteries could not keep up with the motor's amp demands. I puffed a 3s 6000 Polyquest pack. The Maxamps 3s 8000 pack I used took it pretty well though.
4s will be the standard, but 5s and 6s definitely run longer and more efficient. I have raced 3s, 4s, and 5s and my 5s setup is the most reliable and efficient of all three.
Cars I've Owned: Tekno EB48 & SCT410, AE 8.2e, AE SC10 4x4, MBX6e Tekno V4, Xray 808e, Xray 8Te, Losi 810e, Losi SCTE 4x4, Losi 22, Hot Bodies Ve8, Losi 8te, and plenty of Traxxas
Sponsors: Visa, Mastercard, Amex, and my wife's bank account.
Edumakated is offline   Reply With Quote
Old 10-14-2008, 04:29 PM   #33
Xtant3150c,
The reason I posted the vid. link was to show the handling of the RC8, not too get off thread. If a RC8e comes out, O man - it will handle close to the nitro in the vid. That being said, I'm going to have some type of 1/8th 4x4 corr truck using 6s brshless. You can put your money on it! I'll have it.
Tim3 is offline   Reply With Quote
Old 10-14-2008, 04:45 PM   #34
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
again, agreed with everyone here.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-25-2008, 12:01 AM   #35
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
Looks nice...
http://www.neobuggy.net/modules/news...p?storyid=5147
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 11-25-2008, 01:12 AM   #36
UK.hardcore's Avatar
I think they like me.
I buy a RC8T and "poof" they put out a conversion by themselves.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 11-25-2008, 06:34 AM   #37
Tech Legend
Cain's Avatar
thats definitely one beefy motor mount. I wonder how side to side balance is and how well does it perform with one heavy side?
My RC8 has a heavy side since I use the larger 6000mah polyrc battery pack, but doesn't appear to affect handling at all.
Old 11-25-2008, 07:00 AM   #38
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
I did also notice the notes from neobuggy say the battery tray was fitted for the hardcase lipos that are quite common for 1/10th. That's only 138mm long. From what I've seen most of the 4s, 5s, and 6s Lipo batteries are considerably larger than this..... My over all question is, how will this affect battery options?
MikeDeadly is offline   Reply With Quote
Old 11-25-2008, 07:20 AM   #39
strodedawg's Avatar
Trader Rating: 56 (100%+)
what is the part number for the conversion?
Team Whiteknuckle-Jim Mastroddi
TLR 5B-e 8s Futaba/JX/HW/Poseidon RC/SMC
Tekno EB410 Futaba/JX/SMC/SMC/SMC
GRP/Dynamite/Grafil/Punched RC/RC Monster/DE racing/Exotek/Protek RC
Dutch Oven Designs/Pro-line
strodedawg is offline   Reply With Quote
Old 11-25-2008, 10:25 AM   #40
Trader Rating: 32 (100%+)
Send a message via AIM to JDCrow Send a message via Skype™ to JDCrow
80930
MSRP $129.99
AE e-Conversion kit features:
Rigid one-piece motor mount utilizes standard motor screw mounting pattern
Large speed control mounting area raised off of chassis to allow for easy screw mounting of common speed controllers
Speed control mounting area includes convenient switch-mounting boss
Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray
Molded Battery tray supports 7.4-14.8V battery packs with room for foam pads
Accepts two ROAR-approved 1:10 scale size 7.4v LiPo battery packs (#703 Reedy LiPo 5000 PRO (2), #704 Reedy LiPo 5000 w/connector (2), #705 Reedy LiPo 3200 w/connector (2), #709 Reedy LiPo 5000 35C (2))
New sealed receiver box for proper electronics placement
Receiver, Servo, and battery tray remove from car in one piece for easy maintenance and cleaning
Easy bolt-in chassis installation requires no modifications!
Convenient wire routing keeps critical electronic wires out of drivetrain components and simplifies disassembly
Includes two pinion gears (15T, 16T) and two spur gears (46T & 50T)
Comes with all needed hardware to mount components onto chassis
Motor, ESC, and batteries are not included
RC8 conversion requires RC8e body #89523
Supports these batteries
(electronics not included):
#703 Reedy LiPo 5000 PRO (2) #704 Reedy LiPo 5000 w/connector (2)
#705 Reedy LiPo 3200 w/connector (2) #709 Reedy LiPo 5000 35C (2)
JDCrow is offline   Reply With Quote
Old 11-25-2008, 11:56 AM   #41
Tech Legend
Cain's Avatar
Based on dimensions of the 5000mah Pro 12 AWG lipo that AE sells, two packs side by side would give dimensions of the following:
50.8mm Wide
138mm Length
46mm Height
in comparison to a PQ4900mah 4S PolyRC softcase lipo (this is what I ran in MBX5 prior to getting the RC8E)
46mm Wide
140mm Length
42mm Height
I am hoping that AE did leave alittle room to put in some foam pads to tighten things up. Need to confirm what is the exactly dimensions of the tray.
As for finding 4S packs that fit, I think trakpower could easily make a 4S lipo that would fit fine. They already do a 3S hardcased one. Could be easy for them to make a legal 4S case one too.
You may be able to find some 5S packs that could work, softcase of course.
Old 11-25-2008, 01:58 PM   #42
DRRC's Avatar
Trader Rating: 57 (98%+)
that is a small battery tray
a zippy pack 4s 5000mah which costs $85 would not fit in it
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 11-25-2008, 02:10 PM   #43
Tech Legend
Cain's Avatar
I think AE's main goal was to make it so that two 1/10 scale sized packs could be used or one larger 4S 1/10 scale sized pack could be. Especially with where they put the ESC, really not much room for battery.
Old 12-25-2008, 06:57 AM   #44
rearviewmirror's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Has anyone ran this Team AE conversion kit? What battery did you use? I'd like to run a 4S at least.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 12-25-2008, 06:58 AM   #45
MustGoFaster's Avatar
What is the part # for the receiver box?
MustGoFaster is offline   Reply With Quote
Whyalla Offroad Racing AusAnt Australian Racing 9529 09-26-2016 01:16 AM
