Old 10-11-2008, 02:15 AM   #1
stuey's Avatar
Default D4 and lipos
could somebody help what would the measurment be between the top of the lower deck and the bottom of the rear upper deck so i can compare lipos for best fit and performance
thanks
stu rand
2007 & 2008 corally stcc pro stock champion
2007/2008 carpetwars pro stock champion
stuey is offline   Reply With Quote
Old 10-11-2008, 06:56 PM   #2
scott54's Avatar
I'm not near my car to measure for you but I run the Trakpower 4800 and I had to shim the rear deck with 2 .30 washers. Fits fine and there doesn't seem to be any problems with shimming the rear deck to fit this.
Good luck.
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 10-11-2008, 11:49 PM   #3
schmelme's Avatar
Good luck.
+1 i did the same thing for mine. works great. the 3200 trackpower will fit with no shimming.
schmelme is offline   Reply With Quote
Old 10-12-2008, 12:58 AM   #4
stuey's Avatar
Good luck.
that sounds pretty cool but sorry to british on this one but what is .30 in mm or is it in mm.
Old 10-12-2008, 07:30 AM   #5
air8's Avatar
.30" would be 2.1mm???? Someone correct me if I'm wrong.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-12-2008, 12:44 PM   #6
schmelme's Avatar
yeh right around there. I used the purple 2mm HB washers under each hole and the track power pack just sneeks in there.
Old 10-13-2008, 09:15 AM   #7
Matt Phillips's Avatar
If you run the SMC hard case saddle pack you don't have to do any shimming on the topdeck. And the stock D4 body fits perfectly.
Hot Bodies Racing
Team Tekin
Team Trinity
Bodies By celphdesigns.com
Matt Phillips is offline   Reply With Quote
Old 11-14-2008, 08:58 PM   #8
pangRacer's Avatar
Thanks for the info. The SMC saddle pack fits perfectly with the stock body without mod on my WCE. Would much appreciate suggestion on the weight required to balance the setup.
pangRacer is offline   Reply With Quote
Hot Bodies Cyclone D4 EP buggy Mike Schumacher Electric Off-Road 1921 10-06-2014 12:33 PM
LiPO Saddle Pack Dimensions BlueEagle Electric Off-Road 18 11-10-2011 10:27 PM
HPI Racing Cyber 10B wagonman72 Electric Off-Road 332 07-01-2011 10:33 AM
ep 1:10 4wd buggy FortySix Singapore R/C Racers 55 08-18-2009 10:58 AM
23rd Dec 2007 10th scale EP Off-Road Fun Event foampervert Singapore R/C Racers 144 11-17-2007 09:36 PM
