!!!HELP!!! NOVAK GTB SPEKTRUM PROBLEM
hello, i'm having problems with my xxx4 buggy. i have the novak gtb brushless 5.5 set-up and i'm running the spektrum receiver. after about 30 seconds of running it starts cutting out. when i slowly apply throttle it works ok, but if i hit full throttle it shuts down. the spektrum receiver light goes out when this happens. a buddy of mine told me it's because the brushless system is pulling so much power. he's heard that all you have to do is hook up a capasitor to the receiver. does anyone know if this works and if so what size cap. is it something i can get at radio shack or do i have to special order it. any help would be great.
I had that happen also to fix it use the spektrum voltage protector it works great.
http://www.spektrumrc.com/Products/D...ProdID=SPM1600
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
What conectors are you using???I had a similar problem and it turned out to be a bad male deans plug on the speedo.It worked fine until I pegged the throttle then it would just cut out until the spektrum would re-connect to the transmitter.
