2wd buggy mod/stock >
2wd buggy mod/stock
2wd buggy mod/stock
Old 10-07-2008, 01:49 PM
BradBaker's Avatar
Default 2wd buggy mod/stock
This is a thread to talk about your stock and mod buggy setups.
BradBaker is offline
Old 10-07-2008, 02:08 PM
porkey's Avatar
sweet
porkey is offline
Old 10-07-2008, 03:37 PM
BradBaker's Avatar
Originally Posted by porkey
sweet
what are you guys all running?
Old 10-07-2008, 04:05 PM
porkey's Avatar
b4 low grip
shocks-frontbrownwt. 32.5shock mount middle outer
reargreenwt.22.5 shock mount inner/inner(rear)
wheel base (rear) short
c-hubs-30
anti-squat-0
t4 low grip
shocks-frontgoldwt. 35 piston 3
shocks-reargreenwt.30 piston 1
shock mount- front. middle/ inner
shock mount- rear. inner/inner
wheel base- short
c-hubs-30
anti-squat- 2
porkey is offline
Old 10-07-2008, 04:41 PM
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
2- academy gv2 buggies. 1 stock 1 mod.
    2wdMod is offline
    Old 10-07-2008, 05:45 PM
    BradBaker's Avatar
    I have a xxx cr
    Mod
    Losi-xxxcr
    Rear tires-Ifmar pins, Holeshots
    Fronts- Proline
    Shock weight- 30 all around, sometimes 27.5 rear indoor
    Motor-10.5
    Battery-Stickpack(more weight)
    Working on getting a stock set up.
    Old 10-08-2008, 01:10 PM
    BradBaker's Avatar
    Team academy
    Team Associated-B4
    Hot Bodies-D2 Coming soon
    Team Losi-xxx cr
    Attached Thumbnails 2wd buggy mod/stock-akadamy-2-wheel.jpg   2wd buggy mod/stock-b4.jpg   2wd buggy mod/stock-d2.jpg   2wd buggy mod/stock-images.jpg
    Old 10-08-2008, 02:13 PM
    Briguy's Avatar
    Trader Rating: 125 (100%+)
    XXX-CR - Mod
    Lipo with 3 oz weight added
    Front
    toe out 1*
    camber -1*
    30 oil , 56 , red springs
    no limiters w/shock end unscrewed 1.5 turns
    spindles down
    Rack Type
    Camber link , 3-B , 2 washers
    shock location , 3 on tower & out on arm
    Long arms
    Rear
    Camber -1*
    Hubs - back
    27.5 oil , 57 , white springs
    no limiters w/shock end unscrewed 2 turns
    Camber link , 3-B , 4 washers
    Shock location , 2 on tower , out on arms
    short arms
    Pink tapers - Slicks when track is damp
    Pink slicks up front unless track is dry , then tapers
    Briguy is offline
    Old 10-09-2008, 01:43 PM
    RC Dad's Avatar
    Trader Rating: 26 (100%+)
    FTB4 (see avatar)
    19T Quad Mag 23T pinion stock spur
    Shocks-front brown 32.5 wt. shock mount middle/outer
    Shocks-rear Silver 30 wt. shock mount inner/inner(rear)
    wheel base (rear) mid
    c-hubs-30
    anti-squat-2
    Battery centered
    1/2 oz weight in side lower rear shock tower
    Stock ribs in front, Losi red ifmar pins rear
    Accelerates like crazy with all the forward traction I could ever want. Jumps effortlessly but sometimes throws out the back end randomly when drifting in corners. I think more rear weight would help but had Losi 1/4 oz weights and could only get 2 in the opening.
    RC Dad is offline
    Old 10-09-2008, 02:53 PM
    crazy4wdracer's Avatar
    Trader Rating: 25 (100%+)
    Associated B4 Team Kit
    Reedy 19T Quad Mag Spec
    23/81
    Front Spring:Green
    Oil:32.5
    Rear Spring:Silver
    Oil:27.5
    Orion 3800 Carbon LiPO
    Battery Position:Rear
    Wheelbase:Middle
    Front Tires:Panther Clay Bobcats
    Rear Tires:Panther Clay Switches
    crazy4wdracer is offline
