Old 10-07-2008, 02:49 PM   #1
BradBaker's Avatar
Default 2wd buggy mod/stock
This is a thread to talk about your stock and mod buggy setups.
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
"IF YOUR NOT FIRST YOUR LAST"
BradBaker is offline   Reply With Quote
Old 10-07-2008, 03:08 PM   #2
porkey's Avatar
sweet
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 10-07-2008, 04:37 PM   #3
BradBaker's Avatar
Originally Posted by porkey View Post
sweet
what are you guys all running?
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
Old 10-07-2008, 05:05 PM   #4
porkey's Avatar
b4 low grip
shocks-frontbrownwt. 32.5shock mount middle outer
reargreenwt.22.5 shock mount inner/inner(rear)
wheel base (rear) short
c-hubs-30
anti-squat-0
t4 low grip
shocks-frontgoldwt. 35 piston 3
shocks-reargreenwt.30 piston 1
shock mount- front. middle/ inner
shock mount- rear. inner/inner
wheel base- short
c-hubs-30
anti-squat- 2
www.michianarc.com
Old 10-07-2008, 05:41 PM   #5
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 39 (100%+)
2- academy gv2 buggies. 1 stock 1 mod.
  • stocker is set up with the box stock set-up,
    white springs all around
    30 wt oil all around
    b-2 camber link positions all around
    rear shocks at #2 position top, and middle position on arm
    front shocks at #2 position on top, inner position on arm.
    running novak XBR with a novak 17.5 with timing turned all the way down on the motor. Gearing is 35/74.
    powered by 3200 yeah lipos
    mod buggy set-up is almost identicle except for 35 wt oil in front.
    running LRP sphere comp. w/ lrp 6.5 motor. geared at 19/ 86.
    powered by 3200 yeah lipos.
    running 3.75 oz of weight under each li-po (Li-po plate)
2wdMod is offline   Reply With Quote
Old 10-07-2008, 06:45 PM   #6
BradBaker's Avatar
I have a xxx cr
Mod
Losi-xxxcr
Rear tires-Ifmar pins, Holeshots
Fronts- Proline
Shock weight- 30 all around, sometimes 27.5 rear indoor
Motor-10.5
Battery-Stickpack(more weight)
Working on getting a stock set up.
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
Old 10-08-2008, 02:10 PM   #7
BradBaker's Avatar
Team academy
Team Associated-B4
Hot Bodies-D2 Coming soon
Team Losi-xxx cr
2wd buggy mod/stock-akadamy-2-wheel.jpg   2wd buggy mod/stock-b4.jpg   2wd buggy mod/stock-d2.jpg   2wd buggy mod/stock-images.jpg
Sportwerks/turmoil
Futaba radios
Hitec servos
Pro-line tires
Hobbytown usa
Old 10-08-2008, 03:13 PM   #8
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
XXX-CR - Mod
Lipo with 3 oz weight added
Front
toe out 1*
camber -1*
30 oil , 56 , red springs
no limiters w/shock end unscrewed 1.5 turns
spindles down
Rack Type
Camber link , 3-B , 2 washers
shock location , 3 on tower & out on arm
Long arms
Rear
Camber -1*
Hubs - back
27.5 oil , 57 , white springs
no limiters w/shock end unscrewed 2 turns
Camber link , 3-B , 4 washers
Shock location , 2 on tower , out on arms
short arms
Pink tapers - Slicks when track is damp
Pink slicks up front unless track is dry , then tapers
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-09-2008, 02:43 PM   #9
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
FTB4 (see avatar)
19T Quad Mag 23T pinion stock spur
Shocks-front brown 32.5 wt. shock mount middle/outer
Shocks-rear Silver 30 wt. shock mount inner/inner(rear)
wheel base (rear) mid
c-hubs-30
anti-squat-2
Battery centered
1/2 oz weight in side lower rear shock tower
Stock ribs in front, Losi red ifmar pins rear
Accelerates like crazy with all the forward traction I could ever want. Jumps effortlessly but sometimes throws out the back end randomly when drifting in corners. I think more rear weight would help but had Losi 1/4 oz weights and could only get 2 in the opening.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 10-09-2008, 03:53 PM   #10
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Associated B4 Team Kit
Reedy 19T Quad Mag Spec
23/81
Front Spring:Green
Oil:32.5
Rear Spring:Silver
Oil:27.5
Orion 3800 Carbon LiPO
Battery Position:Rear
Wheelbase:Middle
Front Tires:Panther Clay Bobcats
Rear Tires:Panther Clay Switches
crazy4wdracer is offline   Reply With Quote
Dirt Heaven turd ferguson Wisconsin & Illinois Racing 3955 05-03-2016 09:12 AM
$$$MONEY RACE$$$ APRIL 25TH MIKES RC WORLD BELLINGHAM WA cornbinder Northwest Racers 12 04-21-2009 05:42 PM
2009 Midwest Champs @ CRCRC Sneaky Pete Electric Off-Road 605 01-24-2009 06:18 PM
The April Fool's Classic Murf Doggy Dog Racing Forum 16 01-25-2008 11:41 AM
