Old 10-02-2008, 12:51 AM   #1
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
Default Tires off the Rims???
How can I get tires off their rims without harming either one? Boiling? or maybe I can get CA De-Bonder?
RCRat is offline   Reply With Quote
Old 10-02-2008, 12:59 AM   #2
tom_chang79's Avatar
I believe I saw this one another thread similar to this topic, you use Acetone. But not dunk it directly. You use the Acetone vapor. So you just pour some acetone in a container and then you somehow you suspend your rims so it's not soaking in the acetone. You can probably use a small drain strainer but turned upside down and place your wheel on it. Your tires should come right off after a night's exposure to the vapors...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 10-02-2008, 04:05 AM   #3
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
old tub w/seal (no longer used for food prep or storage). 1in bath of acetone in bottom. find somethin to use as stands for ur tires to prop them up off the pool.
go to bed. next morning. everythin will fall off. the tire will be saved (if app) and sometimes the foam (sometimes not, but thats okay).
this is how many of us do it for the track in PA called bumps and jumps where you run slicks, there is no tirewear, but u need to change the foams once every 1-2mths to have them as firm as possible.
good luck
R
UltegraSTI is offline   Reply With Quote
Old 10-02-2008, 06:43 AM   #4
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
P.S. Do NOT soak losi pinks. You can NOT do this to losi Pinks. They will shrink and get hard.
TexRacer is offline   Reply With Quote
Old 10-02-2008, 07:52 AM   #5
glassdoctor's Avatar
I like to bake mine in the oven... not too hot or for too long though.
250* for 15-20 minutes... use gloves... and pull tires off while still hot. I've done that a few times and it worked great for me.
glassdoctor is offline   Reply With Quote
Old 10-02-2008, 08:59 AM   #6
Trader Rating: 19 (100%+)
I did the oven trick. This works great.
I have the oven at 350. Use a sheet of aluminum foil to put tires on
I leave the tires in the oven for 15 minutes only, NO longer and use gloves.
Tires are hot.
They pull apart with no problems.
If you have a little bit of the bead of tire that don't come off, put tire back in the oven for 5 minutes.
I use a standard small head screwdriver to scrape glue off the rims.
I use superglue to keep my tires on the rims and I can get the tires off this way.
Speed Passion-B-Fast R/C-Liverc.com-Dirt Heaven-Revolution Raceway-Venom Designs-M&M Home repair and remodeling LLC-92 Zero Designs.
b4wires is offline   Reply With Quote
Old 10-02-2008, 12:28 PM   #7
johnnyboy's Avatar
Trader Rating: 28 (97%+)
I use the acetone method myself, but if you want to reuse Losi Pink compound rubber then do something else.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Tekno Conversions Thread teknorc Electric Off-Road 10250 01-30-2017 02:30 PM
Ask Aaron Waldron Aaron Waldron Nitro Off-Road 4285 11-03-2011 01:23 PM
Kyosho RB5 with NIP body lp3233 R/C Items: For Sale/Trade 21 04-19-2009 08:22 PM
HPI Challenge (SINGAPORE) 2009 SIA Singapore R/C Racers 89 04-16-2009 09:23 AM
Everything Forsale lucky579 R/C Items: For Sale/Trade 35 04-23-2004 04:56 PM
