Old 09-28-2008, 11:01 AM   #1
Default B4 blue aluminum shock cap
Is there any downfall the using the blue aluminum shock caps over the stock ones? I really like the way they look but don't want to lose any performance.
Webs215 is offline   Reply With Quote
Old 09-28-2008, 11:17 AM   #2
i use them and like them, dont know if they change the performance of the car or not.
sght4 is offline   Reply With Quote
Old 09-28-2008, 12:42 PM   #3
air8's Avatar
If you use the FT blue aluminum upper shock mounts also, there will be more binding at that point over time. As the anodizing wears off the aluminum to aluminum contact won't be smooth.
But I think AE sells a while delrin plastic sleeve for this purpose. Not sure what the number for it is though.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-28-2008, 12:58 PM   #4
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
the shocks were designed for the black plastic ones.. i was told by an ae factory driver to steer clear of different shock caps..
jamminnay is offline   Reply With Quote
Old 09-28-2008, 07:01 PM   #5
d16dcoe45's Avatar
What possible logical reason is there that you would want to "steer clear" of the factory blue cap or even the Yoke caps? As long as the length is the same, they seal, and they fit properly they should perform identical. Common sense.
The plastic sleeves you are taling about are a Trinity part--they are made to use with the Trinity alloy shock mounts. I wouldn't use the blue alloy caps with the FT alloy shock mounts--they will wear quickly and have a lot of play in a short period of time.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 09-28-2008, 07:50 PM   #6
dravengary's Avatar
I just ordered some because I thought they looked cool after reading this that might of been a mistake
dravengary is offline   Reply With Quote
Old 09-28-2008, 10:35 PM   #7
kdeselms's Avatar
Been using the aluminum shock caps for about four months and have never had a problem with them.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 09-29-2008, 01:26 AM   #8
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
I also use the aluminum shock caps on my B4, T4 and B44...
I made the switch because the eyelet on the plastic shock cap "oblongs" (causing slop) too fast to my liking.
I also use plastic sleeves on the aluminum caps (using Lunsford RC10GT shock mounts on the B44). Like d16dcoe45 has pointed out, aluminum rubbing aluminum wears out both of them fast.
Hibernating...
Team Associated B4 * T4 * B44
Novak BL * Futaba TX/RX/Servos * Hyperion/Megapower Chargers
Orion/Yuntong/Maxamps Lipo * AMB #6655738
jobo_ph is offline   Reply With Quote
Old 09-29-2008, 07:59 AM   #9
I switched to the blue shock caps after breaking one of the plastic ones in a crash. The Al are a lot tougher...
CODMAN
CODMAN is offline   Reply With Quote
Old 09-29-2008, 05:46 PM   #10
I use the Associated 1598 caps with the Trinity 33007 mounts with Delrin bushings and this works very good and very, very smooth.
JLinney is offline   Reply With Quote
Old 09-30-2008, 09:24 AM   #11
Send a message via AIM to Creature
I use them in the rear for my T4, I was shattering them like crazy so I made the change.
Creature is offline   Reply With Quote
Old 09-30-2008, 11:11 PM   #12
I was allways told to stay away from them aswell, i think they can bend in a crash, thats what i heard anyway, i havent had any problems with the stock plastic ones so no reason for me to switch.
Tater salad the stories behind nick names how it stuck at that track is beyond me, good times, short lived, forever missed FHR.
Tater salad is offline   Reply With Quote
Old 10-02-2008, 04:17 AM   #13
Bugle's Avatar
The shock design goes back to the original RC10 which ran aluminium caps so I guess that's what they were designed for..
Then in the early 90's they started offering aluminium caps only on the 'team' versions of the buggy and truck and plastic on the cheaper RC10CE and RC10T 'Sport truck'. Same deal with the B2,T2 'Team' vs 'Sport'. Then with the B3 and T3 they all came with plastic caps. It's just a cost saving thing..
http://bugleboyracing.com/
http://stivesrc.org.au/
Bugle is offline   Reply With Quote
::AE Factory Team T4/J82::Pristine::Spared no expense! Catalyst R/C Items: For Sale/Trade 20 05-01-2009 11:20 PM
T4 FT, 3.0dx, Orion Lipo, etc.... Getting out tatalover78 R/C Items: For Sale/Trade 9 10-01-2008 08:29 AM
Major Sell Out......All Must GO!!!!!!!!!! ovalnator R/C Items: For Sale/Trade 30 07-20-2008 04:18 PM
Oval Sell Off Sale ovalnator R/C Items: For Sale/Trade 21 07-10-2008 11:03 PM
Summer Cleanout Ver2 ovalnator R/C Items: For Sale/Trade 23 08-13-2004 06:26 AM
