Old 09-26-2008, 07:37 AM   #1
Default Why do 1/8 scale buggies have center diffs...?
Why do 1/8 scale buggies have center diffs and 1/10 scale buggies not?
haulin79 is offline   Reply With Quote
Old 09-26-2008, 09:32 AM   #2
UK.hardcore's Avatar
8th have center diff's for better cornering and adjustable brake bias.
Why thenth scale doesnt have them beats me. maybe it didnt work well.
Or it was overly complex to put it in the tiny cars.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 09-26-2008, 09:47 AM   #3
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
I think the slipper acts as a center diff in situations such as landing under power rear wheels first...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 09-26-2008, 10:10 AM   #4
Probably because it was too complex and hard to put it in 1/10 scale, and they run just fine without it, don't they?
Note that 1/8 buggies usually have gear diffs, which are much tougher and dont need adjusting a screw compared to 1/10 ball diffs. Would you really want another ball diff in your 1/10?
Obviously tradition played a role too.
shurcooL is offline   Reply With Quote
Old 09-26-2008, 10:52 AM   #5
Moderator
pc9840's Avatar
Send a message via ICQ to pc9840 Send a message via AIM to pc9840 Send a message via Yahoo to pc9840
Because all the manufactures simply copy the same designs that have been around for years. There's no reason you couldn't put a diff in there. Another option is why are we still using ball diffs and not oil filled diffs? Serpent stepped up and offered an oil diff on the S400 but it seems no one else is jumping on-board this option.
[email protected] <><
"The minimum wouldn't be the minimum if the minimum wasn't good enough"
pc9840 is offline   Reply With Quote
Old 09-26-2008, 11:15 AM   #6
trdsupra88's Avatar
I like my balls...low maintenence, never leak...
I cut my own hair ☆
Old 09-26-2008, 11:57 AM   #7
saw
a lot of the older four wheel drive 1/10 scale vehicles did have a center diff
saw is offline   Reply With Quote
Old 09-26-2008, 12:03 PM   #8
Because electric cars don't have mechanical brakes, so there's no way to adjust brake bias...
Fastfreddy74 is offline   Reply With Quote
Old 09-26-2008, 10:34 PM   #9
Does the Losi 8e have mechanical brakes?
Old 09-27-2008, 01:17 AM   #10
No, it uses a standard 1/8 electric direct motor approach.
Unless you take a regular 8ight and use the TeknoRC conversion kit on it.
Old 09-27-2008, 02:29 AM   #11
avrcguy's Avatar
I've actually been considering locking up the center diff in my Caster Fusion EX-1 just to see how it would handle. I really don't see a huge advantage to a center diff in an electric 1/8th scale. Seems like the extra braking would be quite helpful. Of course you would have to be a little careful on the throttle in order to keep the nose down.
avrcguy is offline   Reply With Quote
Old 09-27-2008, 09:40 AM   #12
ta_man's Avatar
Trader Rating: 151 (100%+)
Going from 10K to 7K in the center diff of my Losi 8ight conversion helped handling (turning ability).
ta_man is offline   Reply With Quote
Best Electric Buggy Warhead72 Electric Off-Road 17 02-04-2007 10:01 AM
