Old 12-01-2003, 08:51 AM   #61
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Originally posted by rgb24
Can someone please tell me the part numbers for front and rear a-arms and front spindles and rear hubs for the BK2. do you know if parts are available yet, I don't want to get a new car if parts are not available yet. also are the shock towers the same as the old car. will the old wheels fit.
rgb24- I wish I had some part numbers for you, as I also need some spares. Don't let that discourage you though, I am sure most shops stocking the new kits will also be stocking basic replacements parts very soon...The towers ARE the same, front and rear and 'old' wheels WILL fit, including standard-widths, 5 spokes, etc.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 12-01-2003, 03:21 PM   #62
I just ordered mine today, should be here Friday. the buggy doen't come with a manuel that has the part numbers in it. How much different is the setup for the new car versus the old car. also could you post or email me your setup you used on the indoor high bite track or just let me know what you changed from the kit setup. thanks
rgb24 is offline   Reply With Quote
Old 12-12-2003, 11:11 PM   #63
RCGaryK's Avatar
This is right out of the Price list/exploded view sheet that was in the box with the BK2:
Front Arms: a-9700
Front Spindle and Carrier: A-1122
Rear Hub Carriers: A-2128
Rear Arms: A-9800
Front Shock Tower: A-1107
Rear Shock Tower: A-9814
Front Wheels: A-7004
Rear Wheels: A-7104
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-17-2003, 07:16 AM   #64
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
This should be the complete list.
Part # Description Quantity Price
A-9700 Front Arms 1 $10.50
A-1122 Front Carrier 1 $4.50
A-9833 Rear Pivot Plate 1 $6.50
A-4127 Rear Pivot Mount,F 1 $3.50
A-4128 Rear Pivot Mount,R 1 $9.95
A-9800 Rear Arms 1 $11.50
A-2128 Rear Hubs 1 $4.00
A-9984 Cvd's XXXbk2 1 $30.95
A-2938 Trans Case 1 $6.00
A-2940 Trans Screws 1 $2.50
A-4123 Motor Guard 1 $5.50
A-2943 Gear Cover 1 $3.00
A-2941 Motor Plate 1 $10.00
A-2933 Diff Screw/hardware 1 $3.50
A-3074 Tranny Diff Gear 1 $2.50
A-2935 Diff Halves 1 $14.00
A-2937 Idler gear/pin 1 $2.50
A-9932 Slipper Gear shaft 1 $11.95
One of the team drivers gave it to me. This list does not include any of the "Bling Bling" items such as gold hinge pins.
You May also need A-6094, I think the rear hinge pins are longer then the ones on the old car, not sure though.
Jared Kirkwood is offline   Reply With Quote
Old 12-19-2003, 09:38 PM   #65
Does anyone know if the problem with GP3300's fitting was solved in the bk2? I orderd two assembled promatch GP 3300s and I was just browsing their site and found this this, will the packs fit if they assemble them?
AE Racer is offline   Reply With Quote
Old 12-19-2003, 11:07 PM   #66
RCGaryK's Avatar
I noticed this when I built my KE2. I think once the foam spacer gets compressed a little, the packs will come out much easier. I just pulled the pack out of the back first instead of the front.
HorizonHobby.Com
Old 12-19-2003, 11:31 PM   #67
They do fit though? I havent assembled mine yet and the packs havent come in yet so Im just concerned about what I read on the promatch site. Do you think they will fit with promatch's assembly?
Old 12-19-2003, 11:33 PM   #68
DerekB's Avatar
The problem with the cells fitting isn't the length, but the width of the GP cells (rumor is they are shrinking to be standard size). It's best to use flat battery bars to keep them as narrow as possible and if it's still tight ditch that clear chassis protector and use some thinner electrical tape. They should fit just about right.
DerekB is offline   Reply With Quote
Old 12-19-2003, 11:44 PM   #69
RCGaryK's Avatar
The pack I used was a Fusion one, so like Derek said the thin bars shouldn't be a problem. My issue was front to back, the fit was really tight until I realized why.
Derek, you sending anyone out to cover the Novak race?
HorizonHobby.Com
Old 12-21-2003, 08:34 PM   #70
SlobbaTech's Avatar
You can just trim the battery foam pad a little with some scissors where it meets the forward rear pivot mount. It just fits tighter in BK2 than XXX b/c now there is a little plastic part in front of the shock tower where the pad goez.
SlobbaTech is offline   Reply With Quote
Old 12-23-2003, 07:56 AM   #71
ned911's Avatar
The setup sheet for the BK2 is now available at LosiBoard.com, db is also ready so you can store your setups or review others.
Ned
ned911 is offline   Reply With Quote
Old 12-31-2003, 10:57 AM   #72
highwayman's Avatar
Ran the BK2 last sunday and may i say i was quite impressed... the steering was good, balance on the jumps was impecable... overall i can't say that i want to change anything in the car, set-up wise...
highwayman is offline   Reply With Quote
Old 01-03-2004, 08:46 AM   #73
highwayman's Avatar
i have some of the old GP's and the a couple of the new green and orange shrink wraps, and the newer ones do really tend to fit better than the ond GP's.
but...i did notice that the newer ones tend to have higher peak voltages, even when brand new...
Old 01-03-2004, 04:39 PM   #74
Brian Miskolczi's Avatar
Trader Rating: 156 (100%+)
No kidding they have higher voltage than your older cells....The newer cells are much more power because of the on going process of voltage increasing. GP does make good cells.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 01-21-2004, 10:38 PM   #75
Anyone have problems with the gear cover? I got a old style one in my kit, it's not even near to fitting. At lease Losi is replacing it.
Shawn Plume
www.pmhobbycraft.ca
Frantic Racing (Est. 1988)
Ophidian is offline   Reply With Quote
