Xxx-ke2
#46
Any Q's about this kit....? (Besides when it will be in stores)
I have been running mine for a few weeks on an outdoor track with a bumpy, fluffy-to-sometimes-hard-packed, red clay surface. The updated/revised diff is holding up really well; staying 'smoother' longer, as are the new gears in the tranny. All of the new parts are very durable, too, as I have yet to break ANYTHING at all.
#48
The diff itself- besides the dimensions of gear- is different, yes. It uses a really trick new diff screw that is machined with two circumferential slots just inside the head that allow you to insert two of blue foam washers. The use of two of the foam washers makes for a nice dust-resistant seal inside of the outdrive. There is also a slight revision around the thrust assembly, using a combination of standard thrust washers and beveled washers. On the baskside on the diff, a spring has replaced the stack of beveled washers. And of course, it is placed lower and further forward on the rear of the car.
#51
I know this is the wrong thread but I can't wait to get my hands on the mini-t.
#52
JohnB- The plastic slider outdrives WILL fit, I'm pretty sure, but you will probably have to shorten the length (slightly) of the actual male and female slider shafts. I haven't personally tried sliders on the BK2. The universals and CVD's that fit the new car are a little shorter than standard XXX measurements.
#54
Tones- It is going well. I have only made minor changes on the tracks I have been to in the past 6 weeks; springs, hub positions...I am running on high bite indoor clay this weekend, so it should be interesting to test the optional holes on the arms and hubs, if warranted. I will try to post specific set up info later in the week.
#55
It was officially shipped today
#56
where u get the news? cause its not on the losi site
#57
Can someone please tell me the part numbers for front and rear a-arms and front spindles and rear hubs for the BK2. do you know if parts are available yet, I don't want to get a new car if parts are not available yet. also are the shock towers the same as the old car. will the old wheels fit.
