t-maxx
Old 09-15-2003, 08:39 PM
Default t-maxx
The instruction said that if I tune my t-maxx correctly, it would be hard NOT to do a wheelie. But I find it impossible, is it me or is the instruction is wrong?
BIGGERSTUFF is offline
Old 09-16-2003, 01:25 PM
corvettecrazy's Avatar
how stiff are your rear shocks???
also what are you running on? Tires?
corvettecrazy is offline
Old 09-16-2003, 03:01 PM
it is completely stock.
Old 09-16-2003, 03:27 PM
i know but my friend has a completely stock one and they put spacers in the shocks to stiffen them up...well he couldn't pull wheelies so he tried removing them and now he can pull them all the time...also it is alot easier for him to pull them on grass due to increased grip over my drive way he can do them well in the dirt too.
Old 09-16-2003, 03:43 PM
i see... I will try and remove the spacer. But it is so hard to tune the engine, some time I see a big difference depending on the weather too! is there any way I can tell if the engine is in good condition?
Old 09-16-2003, 04:33 PM
try removing the spacer that should help
weather makes a HUGE impact on how your truck runs...for example if I start running around 5 then run it till about 7:30 because it gets so much cooler out and the air gets more dense it is necessary for you to richen the needle settings.
so yes you will need to make slight adjustments to your tunning as the weather changes
as for testing an engine...you can test compression by turnig the flywheel with your fingers (glow plug must be in and tight) and if there is some resistance good, normally the more the better...OR you can take a trip to you LHS(local hobby shop) and have them test it with a compression gauge and they will be able to tell you more accurately the condition of your engine.
