Old 09-19-2008, 06:23 PM   #16
porkey's Avatar
Originally Posted by JeromeK99 View Post
Hmm.. well.. water in tires w/foam = bad....
you get nasty mildew... tires out of balance... foams breakup and shrink..
Holes in tires.. rims.. whatever.. fine.. but water is still bad..
Just don't dunk tires... fixes the problem.
Jerome
u guys dont under stand it do u, even pros put little holes
and this dose help your foam IF u dunk your tires
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 09-19-2008, 06:42 PM   #17
JeromeK99's Avatar
Well.. the pros put a hole in the tire or drill larger holes in the rims.. not for water.. but for air to escape...
This is so when you jump or the tire takes some force the air gets pushed out of the hole... if it doesn't come back.. the tire gets flat spots and gets "loppy".. a bigger hole or hole in the tires allows the air to come back faster...
water = bad
What's happening to your tires is from water...
I can reuse most of my foam if I wanted too.. they look just about how they did when I put them in... and the tires never felt flat because of the foams shrinking up..
Anyways.. good luck and have fun!
Jerome
JeromeK99 is offline   Reply With Quote
Old 09-19-2008, 07:08 PM   #18
water = bad
Jerome
you need to read more rc car mags cause i have only been into rc for 3 years and i have seen this in articles and at the track and it is done for the reason of getting dirt and water out of the tire.
sght4 is offline   Reply With Quote
Old 09-19-2008, 07:24 PM   #19
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Chill on the hating fellas your all right.
But here's the real deal. never buy wheels with holes and if you do tape them over in and out. Holes should only be on the tire, 2, 3 4 holes will do it depending on how fast you want air to regain the foam. Its a tuning option along with the foam.
Note the waffle pattern inside the tire.
Now a trick to stop those tires from eating the foam is to put duct tape around the foam but not tight just to the diameter of the foam insert.
This will help hold the foam together but will make it harder for water to escape. Bashers can get more out of there stock foam this way seems how most don't wash there tires.
So don't beat me up to bad if my thoughts aren't up to the same speed as yours fast or slow.
BTW those tires are obviuosly over wet at one time or another.
UN4RACING is offline   Reply With Quote
Old 09-19-2008, 07:35 PM   #20
carbon madness's Avatar
Holes in the wheels is for air flow to help keep the car form getting upset from going over bumps, landing jumps, ect., but people have found that with the help of centripetal force a hole in a tire will well help some of the stuff that might get in them come out. Although if you are running in mud, then the water will really never have a chance of coming out as the water will get in just as fast as it gets out.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 09-19-2008, 07:43 PM   #21
Suspended
Originally Posted by porkey View Post
no i dont i just say what i heard and what i have read!
then preceed each statement with that.
otherwise you're just passing on second hand information, might be right might be wrong, and you shouldn't do it unless you yourself have personal experience with it.
cracka is offline   Reply With Quote
Old 09-19-2008, 07:46 PM   #22
Suspended
Originally Posted by MajorPede View Post
If you put a second whole in the Tire, as I and alot of other racers have done. It trows alot of the dirt back out.
Keep doing it, and believing it does everything you say.
the tire and foam companies will be happy for the extra business
Old 09-19-2008, 07:51 PM   #23
Originally Posted by cracka View Post
Keep doing it, and believing it does anything.
I agree with that, as I have had more tires go bad for traction compound (like my pink taper pins) then water getting in them (Most of my other tires used on dusty tracks, or tracks with some light mud). I only put a hole in the wheel, not tire.
マイクル ユージャック
Old 09-19-2008, 07:51 PM   #24
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Pros don`t pay for their tires and use up several sets in one raceday . And the holes are for letting dirt and any moisture getting out from running on the track . Not dunking them . Dunking will ruin foams no matter how many hole you have in the tire .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 09-19-2008, 07:54 PM   #25
porkey's Avatar
i do have experience w/holes in my tires all of my tires
have holes
www.michianarc.com
Old 09-19-2008, 07:55 PM   #26
porkey's Avatar
NO it dosent im not going to argue w/ u about this
www.michianarc.com
Old 09-19-2008, 07:55 PM   #27
Suspended
what PRO's do you know that you can make that statement?
Old 09-19-2008, 07:57 PM   #28
porkey's Avatar
i look at there tires they r mostly on there 8th scale!
www.michianarc.com
Old 09-19-2008, 07:57 PM   #29
Suspended
have holes
And how long have you been involved in this hobby, other than just backyard bashing?
Old 09-19-2008, 07:59 PM   #30
porkey's Avatar
i have never bash i race at a track embassy raceway,how
long r u going to harass me!
www.michianarc.com
1/12 forum ovalnator Electric On-Road 46189 12-15-2017 08:13 AM
Formula 1... Darkseid Chat Lounge 15117 12-14-2017 02:17 PM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 04:59 PM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
Serpent 705 Questions. bleach1 Nitro On-Road 30 01-06-2004 09:05 PM
