Old 09-18-2008, 05:43 PM   #16
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Originally Posted by aeRayls View Post
As much as I would like to have a new car, just for the sake of something new to tune on I would be happy with an updated kit.
All plastic parts included no graphite.
The new B44/B4 rear arms included
Front arms molded of the same plastic as the B44/GT2
Gt2 caster blocks included
.080 front shock shafts
B44 rear hubs and bearings included
New wing mount with more webbing like the B44
Revised steering rack like the Gt2!!!!!
CVA's with retaining clip instead of cvd's
STEEL center drilled fornt axels
I like this idea.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 09-19-2008, 12:33 AM   #17
aeRayls's Avatar
Lou, they should atleast consider it right? If they put my car on the box, I'd drop a nut.
RBfive, fo sho They would only have to engineer a couple parts to make it happen. B4 World's Car!!
I've had 4 or 5 B4's and on my 7th T4. I dont see myself getting another till something new.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 09-19-2008, 01:07 AM   #18
scott54's Avatar
That would be badass. How about GT2 QC? or shock caps with bleeders?
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 09-19-2008, 07:29 AM   #19
Suspended
Originally Posted by Anemic_SluG View Post
I think any off-road company should consider making a li-po brushless specific car. I know we can all get it to work but having better motor balance, gearing options for 17.5 motors and removable weights would be awesome. I hate stick on weights, especially when you start the race at weight and end up DQ'd because they fall off and just getting the balance right would be totally plug and play! It would make our hobby that is advancing look better. I don't know how many times someone checks out a $500 touring car that looks like a pile because it has 40 million stick on wieghts making it look like a frankenstien project!
I guess if you want everything done for you, maybe it's time for an RTR.
cracka is offline   Reply With Quote
Old 09-19-2008, 07:44 AM   #20
Trader Rating: 14 (100%+)
A lipo/BL car would sell like crazy i think. Dont need to redesign just bulk up some of the parts(arms for example), weight the chassis, and lower the final drive(smaller diff).
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S
DG Designs is offline   Reply With Quote
Old 09-19-2008, 04:34 PM   #21
They will need the B5 when they lose a race.
Shirk is offline   Reply With Quote
Old 09-19-2008, 04:41 PM   #22
What up?'s Avatar
Just curious but when was the last time an AE car didnt win the worlds or nationals?
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 09-19-2008, 04:45 PM   #23
Jack Smash's Avatar
Trader Rating: 29 (100%+)
They could just come out with a new tranny back to the old school 1.85 ratio and call it good. No need to completely redesign the car.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 09-19-2008, 08:47 PM   #24
J_P
J_P's Avatar
The T4 has won every ROAR National since it was released. That would be starting with the '03 Nats in Tiltyard Va.
The B4 I would have to think about....any one else?
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 09-19-2008, 09:08 PM   #25
carbon madness's Avatar
However you look at it, the B4 and T4 still win races, but if they were to come out with a updated kit, then I would want to see the things aeRayls posted included with the kit. Other then that there really is no need to change the kit.
As for running li-po what more can you really do to a car that has the battery mounted down the center? It isn't a TC where batteries are mounted along the out side of the chassis, so when you use a li-po you have to add a bunch of weight to it to make it ballanced. Really the only reason people add weight to their car is to make weight, and most of the current set-ups just work with the added weight.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 09-19-2008, 11:41 PM   #26
aeRayls's Avatar
B4 has won every Worlds since its release.
Nats 03 Amezcua
Losi in 04 & 05 Robbers/Truhe
06 cav
07 cav
08 cav
Old 09-20-2008, 01:23 AM   #27
Tech Legend
Wild Cherry's Avatar
Wild`s wish list
#1 vertical ball stud`s for ft caster block & back hub
#2 off-set spur gear & motor mount so motor is centered middle of chassis
#3 reposition rear shock tower more forward on chassis....
#4 offer a straight rear arm , no bend on the outside....
#5 A set of rear dogbones just like the losi design ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 09-21-2008, 12:10 AM   #28
Trader Rating: 22 (100%+)
It has nothing about things done for me. I like to build kits, and I run touring car where nothing is right unless you set everything yourself. Just saying times a changing and someone should build a car that has the right gear ratio, and balance. They didn't build the B4 thinking that everyone was going to run Lead Acid 12v batteries, but if we started too run those and someone came out with a specific car to fit those then they would build it or not sell any cars. Better yet if someone comes out with a brushless lipo car and it wins at the club level and prof. level I bet it will outsell the NIMH/brushed designed cars. Look at the rear pod evolution in 1/12th scale. Try to fit a brushless motor in a older model. People are buying new 1/12th scales beause they are balanced and fiit the brushless motors we are all using.
Just a thought.
Speed Passion U.S.A. - Turtlemaster Racing
www.speedpasion.net
Anemic_SluG is offline   Reply With Quote
Old 09-21-2008, 02:36 AM   #29
tom_chang79's Avatar
Originally Posted by Wild Cherry View Post
Wild`s wish list
What advantage does a vertical ball stud offer that a horizontal doesn't? I thought they were mechanically equivalent.
F* the dogbones, bring back the Losi telescopes! Those were the shiznit!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 09-21-2008, 08:53 AM   #30
Suspended
So would you like that on a Silver Platter or just in an bag ??
Thunder Tiger TTR EB4 S3 To Trade Funkymojo R/C Items: For Sale/Trade 7 12-03-2006 01:09 PM
Awesome TTR S3 Roller "FS or Trade" Flash-R.C. R/C Items: For Sale/Trade 5 07-20-2005 10:32 AM
