Old 09-17-2008, 02:31 PM   #1
tom_chang79's Avatar
Default Mamba Max vs. Sidewinder
Aside from the obvious difference in the programming interface (Mamba Max includes a Castle Link versus Sidewinder requiring Castle Link), what is the real difference between these two?
I've glanced at their spec, most likely written by their marketing folks, and couldn't really deduce anything since:
Mamba Max:
Continuous(Current): 100A
Sidewinder:
Continuous(Current): More than you can handle! <------ That's marketing talk!
So what are we actually paying for in performance difference between the two?
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 09-17-2008, 02:39 PM   #2
porkey's Avatar
the mamba is better but for the price of the sidewinder
u will get the same speed the same timing ...etc. i have a mamba and
i love have no problems w/it but u can down load the link on the
CC web sight
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 09-17-2008, 02:57 PM   #3
B-FAST R/C's Avatar
Max vs Sidewinder, SW is limited to 4600: Up to 3s LiPo 12 cell NiMH
or 5700: Up to 2s LiPo 8 cell NiMH
MM up to and including 7700: Up to 3s LiPo 12 cell NiMH
My Max has the USB port on the ESC to plug directly into PC. (tons of options)
My SW needs CastleLink, unplug esc from receiver, plug esc into Castlelink and to computer. Same options)
www.bfastrc.com *** Feel The Diff!! ***
arcshobbies mcculloughsrcracing
B-FAST R/C is offline   Reply With Quote
Old 09-17-2008, 03:07 PM   #4
Trader Rating: 21 (100%+)
The Pres of Castle used to post on RCM and he explained they would not rate their esc in amps since there was no standard test protocol. He said Castle wouldn't inflate their numbers to match competitors to look competitive so their products would be at a disadvantage on paper if they were to rate them. They offer no rating.
I've got both, but haven't used the Sidewinder yet. Have seen nothing about a continuous rating on the forums I belong too.
Duster_360 is offline   Reply With Quote
Old 09-17-2008, 03:25 PM   #5
Actually, that's not true. It's pretty misleading.
With a Mamba Max system, you get a simple USB-miniUSB cable that you can use to hook up the Mamba ESC to your PC's USB port. But it's not the Castle Link that all other Castle systems use, so you will still need to purchase Castle Link for other devices if you wanna be able to program them (e.g. Castle UBEC).
Castle Link includes that very same USB-miniUSB cable and also a miniUSB-3pin servo port device to connect stuff...
shurcooL is offline   Reply With Quote
Old 09-17-2008, 05:33 PM   #6
My friend has tried both the Mamba Max and Sidewinder in the same car and he says the braking in the Sidewinder is not as strong as with the MM. Now I don't know if he had the brake settings the same but he ended up selling his Sidewinder.
thisguy80 is offline   Reply With Quote
Old 09-17-2008, 07:31 PM   #7
SpEEdyBL's Avatar
When the sidewinder was initially released, it was marketed as a 70 amp esc which should give you an idea of how it compares to the mamba max. The amount of programing that can be done is exactly the same as that of a Sidewinder.
SpEEdyBL is offline   Reply With Quote
Old 09-17-2008, 08:26 PM   #8
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
This is what I have found out as well. The MM is about 10% stronger on the brakes than the Sidewinder is, especially when using drag brakes as that is where I see it the most. I use 10% more on my Sidewinders than the MM.
The MM can handle hotter brushless motors and is less likely to thermal than the Sidewinder. I tested my prototype Sidewinder and the Production version Sidewinder and the brakes are the same.
In my 2wd buggy I run the 4600/Sidewinder combo for around 9 months and it has worked great. Now when I run my 4wd car I will use the MM since I will run either the 5700 or 6900 motor and the speedo tends to run hotter in the 4wd car so I will use the MM for that reason.
Both work great and are fully adjustable and updateable with the Castle Link so it is a very cool system.
ST Racing Concepts (STRC)
Old 09-17-2008, 08:29 PM   #9
lutach's Avatar
Any of the ratings can be found here: http://www.castlespecialprojects.com...ntrollers.html
http://www.youtube.com/watch?v=BikJALhTd8s
http://www.rc-monster.com/forum/showthread.php?t=8651
http://www.cnn.com/2008/HEALTH/conditions/04/01/autism.ireports/index.html (My daughter's video is the last one)
lutach is offline   Reply With Quote
Old 09-17-2008, 09:41 PM   #10
Thanks for all the great info guys!
Mamba Max Pro? Is this the rumored Mamba Max with the sensored port?
RIP TAP RC
Old 09-18-2008, 03:54 AM   #11
As far we know (info from CC boss) mamba max pro will be
Up to 5S lipo
Switch BEC
slighly lower power handling then Mamba Max
No USB port, must use Castle link
"Feature port" mostly for Rock crawler use
Mister-T is offline   Reply With Quote
Old 09-18-2008, 04:30 AM   #12
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
So I'm not sure I follow....I assume the MM is the better system. But the Sidewinder is pretty much just as good???.....Yes?
RCRat is offline   Reply With Quote
Old 09-18-2008, 06:26 AM   #13
wyd
Tech Legend
wyd's Avatar
For the most part. If you want to run 4600 and 5700 motors the Sidewinder is great but if you want to run the 6900 and 7700 motors you will need to use the MM. I also think if you are running it in a 4wd car I would use the MM as well as it tolerates the heat better.
I would say if your bashing or just running some local races in mod (not ROAR races) the Sidewinder is fine. I have raced mine for 9 plus months almost every weekend and still works like the day it was new.
Old 09-18-2008, 06:41 AM   #14
RCRat's Avatar
Okay sweet; but the little spreadsheet on Castle's website says that you can't run 3S lipo with the MM 6900 or 7700, correct?
And if so....and you really want to go FAST...the Sidewinder 5700 with 3S is perfect.
You also say "not ROAR races"....do they not allow Sidewinders?
Old 09-18-2008, 08:04 AM   #15
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
I actually run a sidwinder in my 2wd and 4wd. I've never had an issue and the price is right. SO it depends on how fast you want to go, for racing a 4600/5700 should be plenty.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Caslte Creation Mamba Max VS Novak GTB system MannEdge Electric Off-Road 324 06-20-2010 10:07 PM
castle creations sidewinder VS. Velineon RallyImp05 Electric Off-Road 44 04-22-2009 04:36 PM
VXL vs. Mamba Max vs. ORION Vortex mm7700 Electric Off-Road 16 12-01-2008 08:44 AM
Sidewinder vs. Max ? Quinton Electric Off-Road 22 10-28-2008 08:50 AM
Mamba max vs. sidewinder retat Electric Off-Road 54 05-12-2008 11:15 PM
