Old 09-14-2008, 12:09 PM   #1
Trader Rating: 54 (100%+)
Default 4wd fronts on a 2wd buggy: Handling?
Question: What handling changes would one anticipate if running, say a 4wd front Taper Pin on a 2wd buggy, rather than the narrower 2wd front Taper Pin?
WHOBEE is offline   Reply With Quote
Old 09-14-2008, 05:57 PM   #2
It isn't much of a difference except the tire rolls over the wheel more with the four wheel front.
Shirk is offline   Reply With Quote
Old 09-14-2008, 06:13 PM   #3
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The way it was explained to me by my Sensei...LOL...was that you get more initial turn-in with tapers, but less when you're really cranked. I use them pretty regularly when the track is more dried out.
Turbo Joe is offline   Reply With Quote
Old 09-14-2008, 06:32 PM   #4
d16dcoe45's Avatar
On my CR buggy it seems that the 4wd tapers (mounted on 2wd rims, stock foam) gave more turn in but would make the car hook a bit coming out of the turn--a bit more unpredictable. I would try to find steering from other places and stick with a 2wd taper and play with the foam width and type.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 09-14-2008, 06:41 PM   #5
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Panther sells some of their front tires labled for 2wd and 4wd. There really isn't much of a difference though, the 4wd's are just a little wider. I run Panther Clay Switches on the front of my B4, they are labled for 2wd and I love them.
crazy4wdracer is offline   Reply With Quote
Old 09-14-2008, 07:40 PM   #6
JeromeK99's Avatar
The biggest problem you are going to have running a wider front tire is that you will scrub off a lot of speed in every corner.... that is if they grab the type of track you are running on.
This is going to create a start and stop situation every time you turn. More heat to the motor and consistently slower lap times.
I wouldn't do it!
Jerome
JeromeK99 is offline   Reply With Quote
MOTORAMA '08 Jwyche Nitro Off-Road 0 02-13-2008 03:43 PM
1/10 Scale Buggy and Truck Tire Lots, 4wd Fronts! Cain R/C Items: For Sale/Trade 1 05-22-2007 11:22 AM
Buggy 2WD vs. 4WD chicagokenji Electric Off-Road 13 12-17-2006 09:27 AM
Why ep 2WD buggy design different from 4WD taz5176 Electric Off-Road 9 07-31-2005 09:56 PM
Trade Yoke 4wd buggy for 2wd buggy cpatel529 R/C Items: For Sale/Trade 5 03-31-2005 12:01 PM
