Old 09-13-2008, 09:31 AM   #1
Trader Rating: 16 (94%+)
Default novak gtb braking question
i have the spread spectrum verson and whenever i tap on the brake, it brakes hard and the backend on my car spins out. i also fooled around with the epa but that didnt seem to make a difference. any thoughts?
BSS07 is offline   Reply With Quote
Old 09-13-2008, 09:43 AM   #2
Trader Rating: 15 (100%+)
Default braking
Adjust your brakes on the radio. Not sure if that is the epa you are talking about, but on the sketrum radio there is a switch/button on the handle part where you can increase and decrease the amount of brake applied.
uncle everett is offline   Reply With Quote
Old 09-13-2008, 09:50 AM   #3
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I'd restart the setup from scratch.
Make sure your radio is set to where the instructions say.
Pick the profile that best suits your needs.
Sounds like your throttle trim may not have been in the middle of the adjustment range.
You should be able to dial out brake with the throttle trim like described by uncle e.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 09-16-2008, 06:58 PM   #4
rc10 ryan's Avatar
Default Minimum brake
Turn down your minimum brake
rc10 ryan is offline   Reply With Quote
Old 09-16-2008, 07:06 PM   #5
tfrahm's Avatar
Send a message via AIM to tfrahm
+1 -- Very good advice...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 09-16-2008, 07:28 PM   #6
When I mash on the brake my car doesn't stop but continues to roll. A tap causes the tail to swing. I can't win
TLR-22T, RB5/ZX5, DEX408
Spectrum DXR3R
OCRC/WCRC
bprocket is offline   Reply With Quote
Old 09-17-2008, 07:43 AM   #7
I see you have the spektrum controller. Your not using the same profile for 2 different cars are you? Also what receiver are you using with DX3r.
Personally I would rebind , start a new profile and reset the brake and gas set up over. Also what profile are you running on the GTb and have you inadvertenly messed with the drag brake setting on the GTB?
Dynodan
dynodan22 is offline   Reply With Quote
Old 09-17-2008, 07:55 AM   #8
i fixed it already, i was changing the wrong epa
Old 09-17-2008, 02:38 PM   #9
dynodan - I'm assuming your question was directed at me. I'm using the SR3100 RX, default profile on the GTB and my brake trim on the TX is 100%. I've got the min brak set at 7 blinks. Other than that, everything is at default.
Spectrum DXR3R
OCRC/WCRC
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 11:26 AM
New Novak Brusless System danjoy25 Electric On-Road 2688 10-14-2010 09:40 AM
Novak GTB Braking desertbird Electric Off-Road 13 03-03-2009 08:05 PM
