e-kyosho Kanai II Brushless >
Old 09-13-2008, 07:33 AM
Default e-kyosho Kanai II Brushless
hello, I have a kyosho kanai II with this configuration.
esc: mamba max
Batteries: 6600 mha 3s lipo
gears: 13/46, 13/48, 15/46, 15/48
motor: I don`t have, but I want a neu motor, I thought in neu 1509/2D (3300kv) using it with 3s. Is it good choice?
weight: - nitro 1/8tt buggy
Sorry for my English
Regards
jalodo56 is offline
Old 09-13-2008, 02:20 PM
ta_man's Avatar
Trader Rating: 168 (100%+)
Better to use 4S and a 1512.
There is a whole thread on this:
http://www.rctech.net/forum/electric...sion-kits.html
ta_man is offline
Old 09-13-2008, 03:49 PM
ideal setup Or this is what i used on mine before i sold it
4s minimum
Neu 1515 (for me anyway) some use 1512's
13ish pinion
Monster Mamba Max
mwry13 is offline
Old 09-13-2008, 03:59 PM
But I have a 3s lipo, and now I buy the neu motor, my budget is for the neu motor.
Another option is buy Align 600l(1650kv) and use with 25/46 gear.
but the neu 1509/2D is good option for a buggy on 3s, the motor won`t broke no?
Regards
jalodo56 is offline
Old 09-13-2008, 04:41 PM
the esc is the mamba max, and this is bougth.
Regards
jalodo56 is offline
Old 09-13-2008, 08:49 PM
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
1509 is more suited for 1/10 scale. You will want a 1512
Drift_Buggy is offline
Old 09-14-2008, 01:41 AM
ok, I see the Align 600L, is 1620kv, 600sice motor, 65A MAX, whit 3s and gear 25/46 the speed is 40mph whit 11,1v or 25/48.
Is the Mamba Max Sufficient?? Is the Align sufficient for 3s buggy?
Regards
note: The align motor is normally used in helicopters, how t-rex 600 whit 6s pack.
jalodo56 is offline
Old 09-14-2008, 04:04 AM
glassdoctor's Avatar
I would stay away from the 600l motor.
For 3s, I would recommend a 1512 1y or 1512 2d
glassdoctor is offline
Old 09-14-2008, 06:22 AM
Then the 600l motor don`t good option no? is the 600l a bad motor?
is that the 600l price is: 110 usd whit send, and the neu 1512 is 240 usd whit send.
Regards
jalodo56 is offline
Old 09-14-2008, 08:22 AM
another options are the medusa, what is the best medusa for 3s? this is good option no??
Regards
jalodo56 is offline
Old 09-14-2008, 11:11 AM
My configuration will be :
esc: Mamba max
motor: Medusa V2 50mm 2200kv
batteries: 3s lipo
gears: pinion: 13, 17, 19 and spur: 46 metal or plastic
with 19/46 the speed is 41mhp, 17/46 is 36,5mhp all in 11,1v no peak
is it good configuration????
Regards
jalodo56 is offline
Old 09-14-2008, 12:11 PM
helpppp
jalodo56 is offline
Old 09-14-2008, 01:12 PM
I think you will be ok with that setup, and it's a low-cost way to go for now... but it's possible the little 50mm Medusa will run hot. Keep the buggy as light as possible. (how big are the 3s packs you have?)
2200kv won't be super fast on 3s... but it will run pretty good with a taller gear. Try a 16t pinion.
The Align motor has mixed reviews. Some have said it's ok, but others say it's no better than a generic Feigao. It runs hot and it's not very efficient, compared to stuff like Neu, Medusa, Lehner, etc. I would stick with a Medusa or Neu (1509 would also be a good choice to save a few $$)
Old 09-14-2008, 01:45 PM
ok, I buy the medusa 2200kv, I have pack 6600mha 3s, and 2 pack 4000mha in parallel, the weight is 7.7 with all, is the weight good?.
Regards
jalodo56 is offline
Old 09-15-2008, 04:11 AM
Regards
jalodo56 is offline
