Old 09-12-2008, 10:51 AM   #1
RA99GT's Avatar
Default B44 rear ride height
I'm in the process of building a B44. It's setup with a TrakPower saddle pack, LRP Sphere TC, LRP Vector X11, and Spektrum Pro receiver.
When building the rear shocks I noticed the rear green springs were longer than the shock itself, so I put the collars at the top of the shock body. Is this the normal?
After installing everything on the chassis, I checked the rear ride height, and it won't go any lower than slightly above arms level. I think its because of the lighter weight of the lipo battery compared to a NiMh. Did any of you run into this issue? If so, how did you solve it?
Thanks for the help in advance
-MurfDogg Racing- Race One or Chase One! -http://www.murfdogg.com/
My RC Racing Blog- http://ra99gt-rcracing.blogspot.com/
My YouTube Channel- http://www.youtube.com/user/ra99gt
RA99GT is offline   Reply With Quote
Old 09-12-2008, 11:03 AM   #2
aeRayls's Avatar
Shouldnt have been a problem. Do you have the correct spring retainers on the rear? The raised ones for the front or the RPM ones will move the spring up too far.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 09-12-2008, 11:27 AM   #3
RA99GT's Avatar
Ya, I've got the long spring retainers on the front and the normal ones on the rear.
Old 09-12-2008, 11:43 AM   #4
aeRayls's Avatar
Hmmmm, I just took a look at mine and the green springs arent really longer than the shock, about the same length. ??? Got me a little puzzled.
Old 09-12-2008, 11:46 AM   #5
jimcoracer's Avatar
I use 7 x 7gram lead weights under the rear drive shaft.
jimcoracer is offline   Reply With Quote
Old 09-12-2008, 12:12 PM   #6
RA99GT's Avatar
I wonder if the rear springs that came in my kit just happen to be a bit longer than normal? I need to take them off and compare the free length to another pair of green rear springs.
Old 09-12-2008, 12:24 PM   #7
RC MARKET's Avatar
22-23mm
RC MARKET is offline   Reply With Quote
Old 09-12-2008, 12:39 PM   #8
Yeah its because of your lipo battery is so lite. Do you have a NIMH saddle pack? If so put it in and see the difference. I had to put wait in my B44 with the lipo battery it didn't handle well at all without it. All the team drives run like 20-23 isn't it.
chet is offline   Reply With Quote
Old 09-12-2008, 12:50 PM   #9
Trader Rating: 36 (100%+)
22mm front
21mm rear
MikeGonzo is offline   Reply With Quote
Old 09-12-2008, 05:19 PM   #10
Gliptal's Avatar
I'm running the trakpowers and have no problem with ride height. Maybe the springs just need to be "broke in", maybe try letting the shocks sit over night compressed.
I didn't have a problem but I did run a Nimh pack for the first couple weeks. When I switched to the trakpower I added 1oz of weight between them but that's it, i think it handles better with the lipos myself.
Gliptal is offline   Reply With Quote
Old 09-12-2008, 06:50 PM   #11
tom_chang79's Avatar
Any springs - shocks, diff, slipper, etc., need to be "broken-in" before use by fully compressing them. It's a good practice since the springs will sometimes settle at a length when you compress it for the first time. This is especially true for the springs used in the diffs and the slipper assembly...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
XX-4 Forum knucklebusta Electric Off-Road 4036 06-10-2016 06:15 PM
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 08:32 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 08:36 AM
Official J-Concepts BJ4 Worlds Thread DustinR Electric Off-Road 331 07-10-2012 09:17 PM
Team Associated B44 is for REAL tyreguy Electric Off-Road 3181 10-10-2010 11:58 PM
Project Team Kassanova TR3 V2 (Tc3 Truggy) eds24 Electric Off-Road 28 06-28-2009 10:20 AM
