Old 09-11-2008, 08:12 PM   #1
Applesauce's Avatar
Trader Rating: 14 (100%+)
Default WD-40
WD-40 on tires. What does this do?
Applesauce is offline   Reply With Quote
Old 09-11-2008, 08:17 PM   #2
Thistle's Avatar
Send a message via MSN to Thistle
It helps prevent mud from sticking to them, just like Armor-All does. Some people say that WD-40 also softens the tires, but I've never experianced that. (Maybe I didn't let them soak long enough.)
Thistle is offline   Reply With Quote
Old 09-11-2008, 08:18 PM   #3
Send a message via AIM to Creature
It gives it some traction and makes them look brand new as far as shine.
Its not like traction compound in that it doesn't maintain the extra boost of traction for very long.
Creature is offline   Reply With Quote
Old 09-11-2008, 08:28 PM   #4
carbon madness's Avatar
Wd-40 softens up the rubber which in turn gives the tire more grip, and being that it really isn't a lube the tire become sticky, but yet being that wd-40 is like a lube it helps to keep dirt from sticking to the tires.
I like to use it when I race on indoor clay tracks (although I use a traction compound most of the time), or if I am going to let my tires sit for a long time (the rubber soaks up the WD-40) to help keep my tires from drying out.
Also I have found that you need to let it soak in over night for it to really take effect, so it really isn't somthing you will use on race days, and if you do use it be sure to let it soak in to the rubber as long as you can.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 09-11-2008, 09:31 PM   #5
jrwoodchuck's Avatar
Yes it works! But really only on losi tires. And it doesn't work as a tire softner, but it opens up the poors in the tire. The track I raced at in Denver only allowed wd-40 and simplegreen to be used. Once you get use to it, you'll never go back. In fact the track I race at now, most of the racers have switched over to it. In fact I now use a industrial strength stuff called CRC 3-36. But I used WD-40 for years.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 09-11-2008, 09:42 PM   #6
sport10's Avatar
Actually, WD-40 if left long enough will soften the tires. The track I race at also has a gocart track and the cart racers use wd-40 to soften their tires. They spray them with the wd-40 and wrap them in plastic wrap and leave them to set. They check the softness with a gauge periodically. I have been meaning to try it on some RC tires.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-11-2008, 09:56 PM   #7
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
It can make them slippier too if you dont wipe it off.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 09-11-2008, 09:59 PM   #8
Oh yea! forgot and very true..
Doug
TLR 22/M-11
Old 09-11-2008, 10:41 PM   #9
sparkplug1288j's Avatar
Trader Rating: 3 (80%+)
I learn something new every day. Great tip!
sparkplug1288j is offline   Reply With Quote
Old 09-11-2008, 11:02 PM   #10
Mason's Avatar
To support what some others are saying, WD40 is not a race day tire prep. Depending on the track it may even attract material which is generally not helpful. Its best purpose on tires is for indoor wet high bite tracks. Or making the bottom of your chassis look new after you've cleaned it
Once again your results may vary due to track material.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 09-12-2008, 06:17 AM   #11
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Before a big indoor offroad race, I like to do about 4 heavy coats of WD-40 on the bottom of my chassis and A-arms on my FT B4/T4.. This helps the dirt not to stick your chassis for them wet, indoor high bite tracks. Dirt can build up on your rear T-plate.
Always worked good for me!
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-12-2008, 07:20 AM   #12
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
From my personal experience, i have noticed that WD40 actually does soften the tires a bit. It actually works quite well. I have used it on M2 compound tires and it helped with traction. Give it a try and see how it goes.
Bulldawg R/C Batteries and Products
Nimh and Lipo Batteries and accessories
www.BulldawgRC.com
Team Driver for: Proline, Team Epic/Trinity, Hex Crew, Bulldawg R/C, Speed Demon Hobbies ~~~~TEAM CRUNCHY~~~~
Bulldawg RC is offline   Reply With Quote
Old 09-12-2008, 07:41 AM   #13
dravengary's Avatar
WD-40 works alright on tires it works better in my opinion to help keep stuff from sticking to a arms and chassis I perfer to use Simple Green on my tires Put on night before wipe off after about 10 min and you can feel the stickiness and it is all good when it is sticky
dravengary is offline   Reply With Quote
Old 09-12-2008, 08:04 AM   #14
Applesauce's Avatar
Thanks for the info Guys. Can you tell me the application steps?
Thanks again for the info.
Old 09-12-2008, 08:40 AM   #15
Spray on tires, let sit over night, wipe off next day, go race.
If at the track and you want to use it, I would spray some on a rag, and then rub the w-40 into the tires, but I wouldn't do that unless you have about 1.5 hours before that car is up again. It is also a good idea to keep your tires clean after each run. When at the track you are better off using simple green or some other traction compound (I like to put simple green in my tire cleaning tub (just a plastic tub with a brush glued to the bottom) so they become clean, and sticky).
マイクル ユージャック
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Come on Losi - New 4WD Buggy Drift_Buggy Electric Off-Road 151 06-06-2014 09:07 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 09:27 AM
EP 1/10 Touring zafira2310 Indonesia Racing 10142 06-19-2010 12:09 AM
★★RC 1:10 TAMIYA TA-05 Chassis (2-BELT DRIVEN 4-WD)★★ iamaboy R/C Items: For Sale/Trade 10 04-02-2009 09:00 AM
2008 COLEMAN CUP too twisted Australian Racing 71 10-05-2008 03:14 PM
