Old 09-09-2008, 04:56 PM   #1
whitrzac's Avatar
Trader Rating: 96 (100%+)
Questions?? here's a riddle for you
ok, I have a GM racing V3R esc rated for 18t at 6 cell, I can run a 19t reedy spec(flame lable) with an 8 cell pack, the esc gets to about 130*, and the motor gets to 160*
hot, but not too hot, obviosly the esc is under rated.
today I wanted more torque, so I put a 27t monster stock motor in it and ran it with 6 cells because my 8 cell was charging, the esc stayed around 100* but the motor fryed itsellf at 400*+ I checked the trany for any binding and found non got one of my other monster stock motors and tryed it again, makeing sure that the mesh was set right and that it rolled smoth, I stoped that motor from frying at 200* after 3 min. of runing.
whats happaning??????
this is a stampede with the stock sper and 22 tooth pinion both times
whitrzac is offline   Reply With Quote
Old 09-09-2008, 04:58 PM   #2
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
sounds overgeared......
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 09-09-2008, 05:37 PM   #3
whitrzac's Avatar
I was thinking that to, but why would a 27t overheat and a 19t not?
I have more pinions on the way
Old 09-09-2008, 10:44 PM   #4
tom_chang79's Avatar
First, are you properly meshing the gears?
The gears cannot be mashed together. You have to leave an ever so slight gap between it. I usually feed a strip a paper between the spur and pinion and squeeze. Then tighten the motor, then back the paper out. The thickness of the paper should give you a perfect mesh between the two gears.
Second, torque and rpm doesn't necessarily oppose each other as the winding of a motor goes up and down. Remember that heating in a motor is through power dissipation. Motors draw the most current when it is stalled. As loading increase on the motor shaft, the condition is going towards a stalled shaft. Off-loading the motor for load can be achieved by increasing the gear ratio. Assuming that you have no binding and your mesh is correct, all signs point to over gearing...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 09-09-2008, 11:02 PM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
The peak pinion threshold is higher with the 19t because its got bearings. The stock is over loaded with not only the gear but the bushing. Poof.
UN4RACING is offline   Reply With Quote
Old 09-10-2008, 10:50 AM   #6
whitrzac's Avatar
that makes sense, except that I chaned the bushings to bearings in one of them. IDK, it dosn't realy matter, I was just wondering what happend
besideds, a 19t in a stampede with a 8 cell is FUN
Old 09-10-2008, 11:57 AM   #7
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Electric motors don't like to be stalled. When they're moving slowly or not at all, they're essentially a dead-short. A 27T in a stampede just won't have the "beans" (power) to move the truck easily...a 19T with 8 cells will have the power.
Bog it down and it gets hot. If it's overheating that badly, you need to use a LOT smaller pinion.
Turbo Joe is offline   Reply With Quote
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 07:04 PM
fun at the track Joey Platinum Nitro Off-Road 113 04-21-2012 10:02 AM
