Old 09-09-2008, 02:53 PM   #1
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Default 19T Gearing
What is a good starting point for gearing on my B4 with a Reedy 19T Quad Mag Spec Motor. It is on an outdoor track, the straightaways aren't very long. I am running a 2s 25c 4000mah lipo and an 81T spur gear. thanks in advance for the help!
crazy4wdracer is offline   Reply With Quote
Old 09-09-2008, 03:17 PM   #2
Tubaboy's Avatar
Start at a 19.
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 09-09-2008, 04:04 PM   #3
Trader Rating: 36 (100%+)
Be sure to watch your run times...that brushed motor will burn the brushes after 6-8 min of that lipo...
MikeGonzo is offline   Reply With Quote
Old 09-09-2008, 04:29 PM   #4
OK, this is a big race anyway so I will be changing the brushes every heat. So would a 19 tooth pinion be a good starting point then?
Old 09-09-2008, 07:14 PM   #5
sport10's Avatar
For the most power and if you are going to be changing the brushes after every run try using trinity F brushes.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-09-2008, 07:35 PM   #6
OK, Right now I am using Reedy 676 brushes and I also have some Putnam Greens.
Old 09-10-2008, 01:21 AM   #7
Slightly off topic but with my b4 im running the checkpoint 19T money motor, these motors are awesome btw and need to be geared alot taller, i've got a 24 pinion with stock spur, and it still has awesome torque like it was undergeared by a few teeth, motor comes off at 160* as well with 4600 ener-G cells.
Tater salad the stories behind nick names how it stuck at that track is beyond me, good times, short lived, forever missed FHR.
Tater salad is offline   Reply With Quote
Old 09-10-2008, 08:02 AM   #8
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
For a truck (bigger tires) I'd agree with tubaboy, but not in a buggy.
I run a quad mag in my B4 geared 23T or 24T pinion on the stock spur, same as we run on XXX's. Our track is medium sized with several tight sections and a long straight. With the 23T pinion I get good response in the tight sections but top out early on the 180 ft straight. Any lower gearing is a waste of the massive wide torque curve on this motor.
BTW I use Reedy 767 brushes for off-road, 769 for carpet in the Quad Mag. The 767 brushes will easily last for 3-4 races if you clean the motor between rounds.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 09-10-2008, 03:24 PM   #9
Thanks a bunch, I think I'll get a 23T pinion then because the staraightaway is shorter than 180ft.
Fastlane Raceway kansasracer Kansas/Missouri Racing 17302 11-12-2017 03:30 PM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
19T Motor Forum Korey Harbke Electric On-Road 550 04-11-2009 08:27 AM
Checkpoint 19turn spec mod party_wagon Electric On-Road 371 04-22-2007 12:39 PM
Why are 19 turns faster? [email protected] Electric On-Road 9 10-19-2006 11:33 AM
