Tekin Redline RS Sensored ESC and motors, opinions for offroad? > Tekin Redline RS Sensored ESC and motors, opinions for offroad?
Old 09-26-2008, 03:14 PM
  #31
idbdoug's Avatar
Trader Rating: 33 (100%+)
Will the sensored Redline motors work well with a Novak GTB.
idbdoug
idbdoug is offline
Old 09-26-2008, 04:30 PM
  #32
Trader Rating: 38 (100%+)
I turned the timing up to 100 on the RS Pro with a Novak 13.5. Two stock 330uF caps in parallel. Noticeable more midrange throttle response. The motor ran about 10 degrees F hotter than stock timing, 95F. Still quite cool. Definitely acted like a mild mod.
mattnin is offline
Old 12-01-2008, 07:55 AM
  #33
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Hey guys, I just put in a RS in my RB5 and have to run a 10.5 class (usually run Mod). Anyone have a good hotwire set up to try? I am running an '08 Orion Vortex motor on a small clay track (slick tire track). Thanks.
johnnyboy is offline
Old 12-01-2008, 08:30 AM
  #34
stuey's Avatar
can you explain why the extra cap would do this as its conected to the battery terminal. and also what mode do you have your esc in sensor only or normal
stuey is offline
Old 12-01-2008, 09:08 AM
  #35
Regional Moderator
Exterminator's Avatar
idbdoug
Yes the sensored motors will work with any brushless speed control.
Exterminator is offline
Old 12-01-2008, 09:44 AM
  #36
Team Tekin
Randy_Pike's Avatar
Adding a second cap doesn't generally offer more power. It does however allow the esc to run a touch cooler.
Typical Hotwire setup for 10.5 is Sensored only, motor timing full on(on the motor).
The team has some new software that adds timing boost on top of all of that and should be ready for public release very soon.
Randy_Pike is offline
Old 12-01-2008, 09:50 AM
  #37
Krio's Avatar
Trader Rating: 152 (99%+)
I was given the opportunity to try the "pre-production" version of the new boost software with my novak 17.5 in a b4. Lets just say I need to gear down because I'm still accelerating at the end of the 120 foot straight.
Krio is offline
Old 12-30-2008, 03:17 PM
  #38
Team Tekin
Tekin Prez's Avatar
Absolutely gear way back and work back up. The new timing boost adds a lot of no load rpm and you need to gear back to find the new sweat spot. Heat is still king, but lots of timing can trick you. The motor can be reasonable temps at 3min or so and then skyrocket quickly. If you are setup for a 6min run, a full lipo run can also get away from you.
It is unfortunate that we are setting people up to be overgeared. Good thing these are pretty durable BL motors and not brushed motors or there would be a lot of smoked windings.
Tekin Prez
Tekin Prez is offline
Old 12-30-2008, 05:07 PM
  #39
Johnny_S.'s Avatar
I wish there were more places that carried Tekins in my area. I tried 4 and none of them even carry Tekin products, my track doesn't have any RS or RS Pros either, just R1s. Is the best way to order these online? This is in the Socal area and the track I'm talking about is OCRC.
Johnny_S. is offline
Old 12-30-2008, 05:38 PM
  #40
yodace's Avatar
whats the recommended gearing for a XXXtcr with a 9.5?
yodace is offline
Old 12-30-2008, 07:07 PM
  #41
Team Tekin
Randy_Pike's Avatar
Hey,
Start out with a 22/86 and gear for the straight away. It's a good starting point not knowing the size of your track.
Old 12-30-2008, 07:11 PM
  #42
whitrzac's Avatar
Trader Rating: 96 (100%+)
Tekin Prez
whats this "new" timeing boost? has it been relased yet? can I get a beta version??
whitrzac is offline
Old 12-30-2008, 08:46 PM
  #43
viperbill1963's Avatar
Default tekin 10.5 gearing
hey guys where should i start gearing a 10.5 redline brushless setup in a b4 small to medium track with aprox. 50 to 75 ft long straight ,should i stay with the 81 spur or change to a smaller one ,trying to get my set up tuned in for this weekend ,4600 nimh batteries ,hard packed surface some slip thanks .i have the hot wire on order
viperbill1963 is offline
Old 12-31-2008, 09:43 AM
  #44
Team Tekin
Tekin Prez's Avatar
We are making progress, but still have some work to do. We are making a real grass roots effort with the brick and mortar shops and tracks to support them. Please keep asking them and hopefully they will bring in a few porducts and see some success. You can also let me know which shops and I will contact them directly.
Contact Randy for a Beta version of the new software. Should be posted public pretty soon as well.
Tekin Prez
Old 12-31-2008, 10:23 AM
  #45
whitrzac's Avatar
thanks, I sent him an email.
so how does it advance the timeing?
whitrzac is offline
