Old 02-23-2009, 05:37 PM   #181
Trader Rating: 48 (100%+)
Ok, I have the KV rating of the "others" you mentioned....Thanks for the info.....
ambo is offline   Reply With Quote
Old 02-24-2009, 10:33 AM   #182
big_boss's Avatar
Default RS Pro with 5.5 redline
Hi All
I have the RS Pro with a 5.5 redline in a 4x4 buggy (Academy), ran it for 2 weekends at our track and I'm very pleased with this combo.
My question is for Randy but any body with insight can chime in ...
At the moment I'm running the box stock 180 ver hotwire in dual mode.
Is there any advantage in running the 189 beta ver in my case (dual mode in an offroad buggy) ? or another way of asking is there a difference between the two in an offroad buggy with a 5.5 motor running in dual mode ?
Here is another question, suppose I have the 189 ver on my laptop, will it be beneficial in any way running "sensored only" with boost ?
Any help welcome.
Losi 8ight brushless, Losi xxxt-cr, Losi jrxs type R, Losi street weapon,
Rc10T1 rebuilt, Rc10 "worlds" .Xray T2, Atlas YM-34, Losi XX pro SE
TRC Predator Lynx 2. Tenth Technology super touring, Predator X-10, X-11.
Losi Micro-T, Losi Mini-T, Rc18T, Xray M18
Schumacher Fireblade Evo. All Electric
big_boss is offline   Reply With Quote
Old 02-24-2009, 11:21 AM   #183
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Hey,
189 has a harder launch over 180. When you have 189 loaded you have the option of 180, 183(has harder launch and NO boost) and 189.
189 and boost is generally ONLY for spec type racing. For a 5.5 stick around 30-60 on dual mode timing.
Boost is not recomended or needed with mod motors.
Try this setup for 4wd mod with a 5.5 or 6.5.
Tekin Redline RS Sensored ESC and motors, opinions for offroad?-rs-mo-4wd.jpg
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-24-2009, 01:45 PM   #184
big_boss's Avatar
Thanks Randy for the quick reply.
I'll try the timing advance (mine is set at the recomended 12*)as the rest of the settings are pretty close to what I have at the moment.
Maybe even this weekend if the weather holds.
Old 02-24-2009, 04:24 PM   #185
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Post set up for stock
hey guys i am racing at the battle at the beach in a few weeks and i need a setup for a stock buggy (assoc b4) where should i start with the gearing its a small bluegroove track about a 150 ft racing line .
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 02-24-2009, 04:38 PM   #186
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
i'm lookin at this 189 and i cant help but say i'm lost. the descriptions are not enuff. where is my torque control and high spd pots lol. any help on what all that timing and boost crud is. i can make my way thru the rest and what they do. but i dont want to be taxing a motor needlessly. 10.5 duo 2wd bug. thx for help
R
UltegraSTI is offline   Reply With Quote
Old 02-24-2009, 05:27 PM   #187
Trader Rating: 18 (100%+)
R
The torque control is the "current limit". Timing boost is degrees of timing *added* to whatever your physical can timing is set at. A page back I think, Randy posted a good starting setup for a 13.5 (or down to a 10.5 motor). Maxed can timing with 12-15 degrees of timing boost on top of that. This is in "sensored only" mode. In dual mode, the timing advance becomes your total timing settings, as the can setting has no effect. 100% on this slider equals 30 degrees.
This was the setup he (Randy Pike) posted for a 13.5
KSimmonds is offline   Reply With Quote
Old 02-25-2009, 10:53 AM   #188
Team Tekin
Randy_Pike's Avatar
WORD! LOL
That setup is the team standard setup for 2wd offroad with both 13.5's and 10.5's. Dial back the 10.5 to 20 degrees to start out.
For a small track like that just drop your gearing with the above setup! Thanks K!
Old 03-02-2009, 01:19 PM   #189
yodace's Avatar
R/C Tech Charter Subscriber
Where can I order a cap? My cap broke off..Cant find it....
yodace is offline   Reply With Quote
Old 03-02-2009, 01:37 PM   #190
Krio's Avatar
Trader Rating: 150 (99%+)
Stormer has them in stock:
https://www.ssl-stormerhobbies.com/c...s&pn=TEKTT3520
www.kriostasis.com
Krio is online now   Reply With Quote
Old 03-03-2009, 04:17 AM   #191
idbdoug's Avatar
Trader Rating: 33 (100%+)
Originally Posted by big_boss View Post
Hi All
Any help welcome.
With that fast of a mod motor definitely put a fan blowing on your speed control posts because they act like heat sinks. If that does not get the temp down you will have to ugly up your body a little. Just above and in front of your speed control you will need to cut your a body a little bit. Cut a small area of your body and pull that section up in the air flow like a ram air scoop. You will be surprised how the additional airflow will keep temps down. Of course this is all based on the fact that your motor is geared around the right FDR.
idbdoug
idbdoug is offline   Reply With Quote
Old 03-04-2009, 09:00 AM   #192
Trader Rating: 76 (100%+)
Originally Posted by Randy_Pike View Post
You got it! Motor timing to start at 20 and go up from there. I've got mine set at 22ish.
Hey Randy, turns out I'll just be running a 17.5 trinity, any suggestions? Or should I just stick with this?
MUDVAYNE is offline   Reply With Quote
Old 03-04-2009, 09:34 AM   #193
Team Tekin
Randy_Pike's Avatar
Start there, you'll be fine. You can always bump up the motor timing slowly if you need more speed. Remember that if you go UP in timing you must go DOWN in pinions...
Old 03-04-2009, 01:38 PM   #194
Timing or boost?
Old 03-04-2009, 04:48 PM   #195
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Randy: YGPM
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
RC10B4/T4 Forum DerekL Electric Off-Road 14343 01-05-2018 10:59 PM
Tekin vs. LRP help storytyme Electric Off-Road 62 08-02-2011 04:55 PM
Help with gearing 17.5 J-T9959 Australian Racing 15 05-07-2009 03:37 PM
What ESC to buy? F-1 Electric Off-Road 26 03-25-2009 08:47 AM
