Old 09-09-2008, 10:29 AM   #1
EvolutionT4's Avatar
Send a message via AIM to EvolutionT4
Default T4 rear chassis plate
Is there a aluminum rear chassis plate thats made for a t4,My screws are stripping themselves out more and more??So im wondering if there is a aluminum upgrade for that by someone??
Team Associated T4
My setup
Carbon chassis set
Lunsford Titanium Turnbuckles
T4 sway bar kit
Lrp ai brushless 13.5 motor and esc
Threaded Shock Bodies
Rpm heavy duty rod ends
Rpm wide front bumper
EvolutionT4 is offline   Reply With Quote
Old 09-09-2008, 10:36 AM   #2
An aluminum rear chassis plate would not help. The stock chassis plate is not being stripped out. Rather, the screws are threaded into the main chassis plate and the gearbox. So, you need to change the gearbox case and/or the main chassis. The only reason why you would have to change the rear chassis plate is if it breaks, which can occasionally happen.
An aluminum chassis plate probably wouldn't work. There is a bunch of flex built into that rear piece, it has to be easy to flex so that the antisquat can be adjusted.. So, if you were to buy an aluminum piece, your t4 would probably run permanently tweaked after a few laps.
071crazy is offline   Reply With Quote
Old 09-09-2008, 10:40 AM   #3
There are shreds of plastic coming out of the threads that are in the chassis plate,What would you recommend for upgrades to the rear so this doesnt happen.
Team Associated T4
My setup
Carbon chassis set
T4 sway bar kit
Old 09-09-2008, 11:05 AM   #4
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Like the the other poster said, there are no threads in the rear chassis plate. The threads are in the gearbox, main chassis and front pivot block. The upgrade that fixes that problem is to make sure you use the correct screws and not over-tighten them.
If they're already stripped and you don't want to buy new parts...you can try using some 3mm screws instead of the the 4-40 screws. 3mm screws have a little larger diameter than 4-40 screws.
Turbo Joe is offline   Reply With Quote
Old 09-09-2008, 11:08 AM   #5
Ok i see what your saying now,My main chassis is carbon and im thinking gear box might need the replacement ill take it apart fully to make sure.
Team Associated T4
My setup
Carbon chassis set
T4 sway bar kit
Old 09-09-2008, 11:29 AM   #6
SQC049's Avatar
Trader Rating: 16 (100%+)
porky, is that you porky?
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 09-09-2008, 11:33 AM   #7
That's funny right there, I don't care who ya are.
cjtamu is offline   Reply With Quote
Old 09-09-2008, 11:55 AM   #8
Who are you refering to in this thread??There is 3 ppl who posted before you said this??
Team Associated T4
My setup
Carbon chassis set
T4 sway bar kit
Old 09-09-2008, 12:01 PM   #9
SQC049's Avatar
Ladies and Gentleman of the jury, Exhibit A:
http://www.rctech.net/forum/electric...9-t-plate.html
Just making a joke as there was a thread about this topic not but last week created by someone far less articulate than you.
Andrew Parente
Old 09-09-2008, 12:04 PM   #10
Sorry for that then i didnt see that post would be why i said what i did.I found out it is the gearbox.Both threads are stripped completely.
Team Associated T4
My setup
Carbon chassis set
T4 sway bar kit
Old 09-09-2008, 12:55 PM   #11
porkey's Avatar
no im right here do u need, some thing
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 09-09-2008, 01:08 PM   #12
Turbo Joe's Avatar
NVM...lol
Old 09-09-2008, 03:33 PM   #13
Tubaboy's Avatar
I did this the very 1st time I built up my B4. Yeah, make sure you are using the correct size screw. I accidentally used the 5-40 screws instead of 4-40 which caused the same issue.
And yah, try not to overtighten.
Good luck!
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
***HOBBY SHOP CLOSED BLOW-OUT SALE - ALL PARTS MUST SELL!*** All-Star R/C Items: For Sale/Trade 724 10-19-2010 09:23 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
50% off Street Price! Tons of Parts! All Must GO! racingboy14 R/C Items: For Sale/Trade 55 04-10-2008 07:27 AM
Brand new Team Associated, HPI and More! racingboy14 R/C Items: For Sale/Trade 7 02-28-2008 10:43 AM
