Old 09-03-2008, 08:16 AM   #16
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Lolz...
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 09-03-2008, 12:49 PM   #17
porkey's Avatar
Originally Posted by RB FIVE View Post
Lolz...
what?
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 09-04-2008, 02:18 AM   #18
gfx
gfx's Avatar
Originally Posted by porkey View Post
front brown springs,wt 32.5 rear green springs 22.5 wt i just rebuilded the shocks friday and i check the rears they dont feel blown ill try to different oils
and see where that gets me
How can you tell if a shock is blown? What does it feel like? And when you take it apart, what does it look like?
gfx is offline   Reply With Quote
Old 09-04-2008, 02:37 AM   #19
Trader Rating: 20 (100%+)
You can tell when it's missing a notable amount of fluid. To tell if there's missing fluid:
1. look around the entire shock. The caps, springs, spring cups, ends, etc. If there's oil residue and dust/dirt caked into it - you're probably losing fluid.
2. Flip your car upside down and set it on the table. Let it rest for a few seconds. Manually work your suspension arms up and down and see if you notice air at the top of the shock. You'll be able to detect air from the lack of resistance and a sudden resistance when the piston hits oil. If a shock is full there should be little to no air inside of the shock and resistance should be continuous throughout shock travel.
3. If you remove the cap and the oil is dark, cloudy, dirty, etc.. that means dirt is being permitted through the seals. How that happens is... when a shock is elongated it exposes the shaft to the elements. Dirt, dust, etc can collect on the shaft. Then when the shock is compressed due to a bump or otherwise, the shaft can trap some of that dirtiness into the imperfections of its surface and basically smuggle dirt into your shock. As time goes by the seals can wear out from the friction and begin to permit dirt and leak oil.
Any of these cases could be due to a bad build, or the need of a rebuild.
Shock springs and oils greatly affect how your car jumps. This does not necessarily mean that if your car jumps funny it's the shocks.
First examine your driving style..
If a jump is designed properly you do NOT want to leave the lip with the throttle on. In fact, you want to leave the lip of the jump with a neutral throttle finger so the car can jump by itself without your throttle input. ESPECIALLY if you notice your cars nose flying high. If you notice you're getting squirrely then you can correct yourself by tapping the throttle or brake - but do not leave the jump on-throttle until you know how the jump is built and how your car reacts to it.
-Jeff
JeffEmbracedDC is offline   Reply With Quote
Old 09-04-2008, 04:02 AM   #20
gfx
gfx's Avatar
Thanks, Jeff!
That's some excellent info!
Old 09-04-2008, 04:03 AM   #21
porkey's Avatar
i know when i hit the break it makes it worse
www.michianarc.com
Old 09-04-2008, 10:11 AM   #22
Suspended
rofl
RCabcs is offline   Reply With Quote
Old 09-04-2008, 10:24 AM   #23
Pull some end point out of your brakes if they seem very aggresive. It takes time to learn how to manipulate your car in the air. I haven't mastered it yet but it's a skill to practice.
Pit Trailer 7x14 v-nose The Warlock R/C Items: For Sale/Trade 2 07-26-2008 12:35 AM
XXX-4 nose dives on jumps... what to do. z28mccrory Rookie Zone 10 12-21-2007 06:51 AM
b4 to nose heavy ? Born2Lose Electric Off-Road 19 04-01-2007 03:54 AM
mbx5 nose divin'.. sandrixx Electric Off-Road 13 11-06-2006 12:30 AM
Lot of Kimbrough 48 pich pinions New and used dodgeguy R/C Items: For Sale/Trade 5 10-25-2005 02:16 PM
