Old 08-31-2008, 11:14 PM   #16
OK, thanks for all the help. I think ill run the mamba with a heatsink and some good flow through cooling.
Craig9080 is offline   Reply With Quote
Old 08-31-2008, 11:18 PM   #17
jaejw1's Avatar
Send a message via AIM to jaejw1
depending on the surface... you might need more than just a heatsink to keep both the motor and the esc cool..
good luck
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 08-31-2008, 11:23 PM   #18
Well the Little black pins on the Mamba Micro Pro will be basically flying in wind out a little hole in the body as the wing should act as a roll bar and prevent those from getting squished in a roll-over. And as to hooking up a fan on the motor heatsink, do you just wire it off the main leads comming from the battery?
Old 09-01-2008, 12:00 AM   #19
jaejw1's Avatar
well if u would use a 400 can motor which is perfect for the vehicle and not a 180 size motor u wouldnt have to use a fan.... trustme I have tested a few motors and u are defeating ironmanpurpose bygearingthe 6800 sohigh..... wont be as fastas you think
compare ur 6800kvmotor geared at 12/49 and my 6800kv motor geared at 16/45.... which one do u think will be faster and cooler running
motor review
tire review
OFFICIAL DURATRAX VENDETTA THREAD... jaejw1 Micro and Mini Scales 3209 12-24-2014 01:37 AM
Help me build my RC18R and Vendetta Buggy Krafcik Micro and Mini Scales 17 12-08-2008 12:59 PM
Boat/plane/Heli ESC in a car? RCSteve93 Micro and Mini Scales 6 01-18-2007 04:17 PM
