Old 08-28-2008, 06:35 AM   #1
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
Default Spur Gear wobble...???
On my Slash, when I have the cover off the spur gear and accelerate the spur gear wobbles as if it's bent. I took it off and it is not bent....Could it be that the slipper clutch shaft is bent?
RCRat is offline   Reply With Quote
Old 08-28-2008, 07:55 AM   #2
Isn't that a question that you are in the best position in to answer yourself? I mean, you have the Slash.
But yea, I don't see why it can't be the slipper shaft since you said the spur gear wobbles yet the gear itself looks ok. It could still be the hole in the spur though.
shurcooL is offline   Reply With Quote
Old 08-28-2008, 07:55 AM   #3
driftkinginc's Avatar
does it affect performace at all? Maybe the three screws that hold the Spur Gear on Are loose?
driftkinginc is offline   Reply With Quote
Old 08-28-2008, 07:57 AM   #4
RedBull_81's Avatar
My first thought would be to change the spur gear. Not sure about slashes but on associated cars spurs start to somewhat do that when there worn.
www.eriercraceway.com
RedBull_81 is offline   Reply With Quote
Old 08-28-2008, 02:43 PM   #5
RCRat's Avatar
From closer examination it does appear that the Spur Gear is warped.
Old 08-28-2008, 04:51 PM   #6
DARKWAV's Avatar
I don't have a ton of exeprience in R/C but I get the impression that spur gears tend to have a very slight wobble. Like you can set gear mesh using the strip of paper method, but still find when you rotate the spur 360 that there's a little bit of resistance and binding in one spot.
You seeing something along the lines or do you think you have a more pronounced wobble?
DARKWAV is offline   Reply With Quote
Old 08-28-2008, 08:03 PM   #7
RCRat's Avatar
No this wobble is pretty pronounced and it makes a hideous noise....
Old 08-28-2008, 08:25 PM   #8
jnslprd's Avatar
check to see if the slipper pads are damaged or not installed correctly
jnslprd is offline   Reply With Quote
Old 08-29-2008, 01:12 AM   #9
Pick up a spur gear, you'll need one eventualy and it wont ruin your day as much
Tater salad the stories behind nick names how it stuck at that track is beyond me, good times, short lived, forever missed FHR.
Tater salad is offline   Reply With Quote
Old 08-29-2008, 05:19 AM   #10
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Your not the first person to have this problem . Almost everyone at practice last night with Slashes had the same thing .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-29-2008, 06:36 AM   #11
RCRat's Avatar
Kinda makes me wonder about the quality of spur produced by Traxxas.
Is there another spur manufacturer for the Rusty/Slash?
Old 08-29-2008, 07:00 AM   #12
Briguy's Avatar
I know Kimbrough makes some for many cars .
http://www3.towerhobbies.com/cgi-bin...SM&C=CLB&V=KIM
Royal R/C & Hobby
Old 08-29-2008, 10:56 PM   #13
RCRat's Avatar
I ordered one from Tower....I'll let everyone know how it works out...with pictures!!
Old 09-01-2008, 04:49 AM   #14
tom_chang79's Avatar
It's funny how you mentioned this phenomenon. I just mounted a brand new Kimbrough B4 spur and I noticed that it wobbled too. I think some of their spurs are a little bit wobbly and not perfectly true. I think they're true enough for RCs but I'd definitely wouldn't use them for surgical equipments!
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 09-01-2008, 04:54 AM   #15
Briguy's Avatar
Maybe there is a different problem if a new spur wobbles . Could be the top shaft isn`t true or even a bearing problem .
Royal R/C & Hobby
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 08:59 PM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
New Traxxas Slash 1:10 Electric CORR Truck salteen Electric Off-Road 3949 03-19-2012 09:24 AM
XXX-S : Drivetrain problem HELP!!!! Cain Electric On-Road 8 05-26-2002 08:54 PM
